11-01-2009, 11:52 PM | #1 |
9/16 lug bolts on a 12 bolt
Anyone ever done this??
11-02-2009, 02:54 AM | #2 |
Re: 9/16 lug bolts on a 12 bolt
i dont know but id like to figure out how to put em on the front also !
11-02-2009, 03:03 AM | #3 |
I have 9/16 studs in a 14 bolt 9.5" ring gear sf rear axle, but they were factory...and I wanted to keep the same all around so I put them up front in the 44 also. I had to FIRST get the proper studs then have the rotors and hubs drilled out at a shop (required odd size holes in my application) and slam the studs in. If I had to do again, I would do 1/2" as they are a bit more common and easier to find.
James |
11-02-2009, 07:26 AM | #4 |
Why change to 9/16ths? Are you matching to a heavier front end?
11-02-2009, 12:27 PM | #5 |
naw i just put a 10 bolt from a 03 silverado in the rear and its got big studs in it, id just like to match those ( prolly 1/2 in ish),id also like to figure out how to do a floating rotor in the front so i dont hafto take the whole hub off every time i need to do brakes !
11-02-2009, 03:30 PM | #6 |
Anybody, i guess the 14 bolt axles shafts have a thicker piece where you put the lug bolts on, the 12 bolt is a thin thing.
11-02-2009, 08:00 PM | #7 | |
That '03 Silverado probably has metric threads.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
11-02-2009, 09:26 PM | #8 |
The 4x4 was 7/16" 6 bolt
2 wheel drive was 1/2" 5 bolt Newer trucks used 14mm x 1.5 thread. |
11-03-2009, 03:12 AM | #9 |
sorry orbot for jacking your thread ! ... if you look at the moser engineering web sight , they have a ton of wheel stud options for axles and im shure that you can fid somthing that will work, and if not im shure that they will know someone that dose
11-03-2009, 08:39 AM | #10 | |||
I didn`t realize all the newer use the 14mm lugs.That is the equivalent to 9/16s which was traditionally only 8-luggers.It makes sense to only use one lug size.
