67 Chevy Stepside
help plz with rearend
is a 14 bolt out of a 75/76 3/4 ton 2wd. is it the same rearend in a earlys 80's 3/4 ton 4wd. whice one better for my crew cab 4x4 im replaceing my dana 70
1967 Chevy stepside 1976 BIG DOOLEY 454 turbo 400 4:11 |
Re: help plz with rearend
The 70s will be a better axle, inless the 80s 3/4 is a full floater. I think the only difference is shock mounts, they are longer on a 4wd, but will still work.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
67 Chevy Stepside
how to tell a 14 bolt is full or semi floater
Semi floaters have a small dished hub in the center of the wheel mounting flanges like on a half ton just to center the wheel. Full floaters have a hub that sticks out with bolts in it. On a full floater, the hub and axle shaft are seperate pieces which is the reason for the hub with the bolts in it.
1977 GMC Sierra Grande |
67 Chevy Stepside
got any picture
67 Chevy Stepside
both is FF one is in a 75/76 3/4 ton 2 wheel drive and the other is in a 80's 3/4 ton 4 wheel drive
67 Chevy Stepside
i can buy the 2wd for 200.00 and get the pair out of the 4x4 for 400.00
HORSEPOWER JUNKIE
niether axle will fit your 1 ton without relocating the spring perches on the axles the 1 ton has a perch center of 40.5 and 3/4 tons have a center of 42.5in unless its in a 3/4 ton CrewCab only exception
67 C20 fleetside custom camper 69 El Camino 72 Camaro 52 Dodge b3b 108 pickup |
Not sure if it matters or not, but go with the 70s 14ff. E-brake cables should be the same on your truck as the 14b, so you could just swap them over. If you dont' need or care bout e-brake, then doesn't really matter. The front axle from the 3/4 will be a 10 bolt, but why would you replace a 60 with a 10 bolt?
67 Chevy Stepside
my 60 is staying in the front be a spare for one of my halfton
