![]() Join Date: Aug 2007
The old "best" starter to use topic....
I've searched the archive a bit.... but still haven't found what I want to read. Anyway, my starter (solenoid ?) has had issues with cranking after a long ride. It seems to be getting worse (not so long ride). What is the best, least expensive solution? It has a Hi-Lo/Oreilly auto parts "lifetime" guaranteed starter on it, I think.....
rg |
Moderator
![]() Join Date: May 2007
Re: The old "best" starter to use topic....
"Lifetime" guarantee starters from parts stores are junk. You will be taking it off and replacing it every three months for life. Take it to a local shop that rebuilds in-house, or get a mini-starter.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
![]() Join Date: Nov 2002
start with the easy stuff first. make sure your battery and charging system is working good, check the ground of the battery to make sure it is well grounded. then climb underneath to pull the starter off and have it checked if none of the easy steps helped.
406 Powered
If you want least then get a shield for it or wrap it with the heat reflect they sell.
70 GMC 68 c10 2002 silverado 72 4x4 |
forgot to mention, that I've had this starter since about 2000.....
OK, maybe what I am looking for is your experience with mini starters (skip white ebay?), etc.... don't have much to spend at this time, but need my baby to start......
summit racing mini starters have never let me down in either my small block or my big block
Moderator
Wow...you are lucky! If it lasted that long, pull it off and exchange it for another one. I had my alternator and starter built by a local shop. No problems ever. I like the mini starter cause it sounds bad a$$ when I crank it, and it only weighs 8 lbs as opposed to about 30.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man Last edited by leddzepp; 11-02-2009 at 09:06 PM. |
#9 | |
Grandpa in the rustmobile...
what does yours do, mine feels like i dont have enough juice to turn the motor over? wtf, maybe i should have my batt. checked someday..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
think a rebuild would be enough i done those myself for a living and if there good they replace all bearings ,the solenoid inners ,the brushes and recut the eeeh not sure about the english word for it the stator i think replace the sprocket in the nose and paint before reassemble we trew all aloy parts in a polisher after dissasembly wish hardened the metal some and gave it a like new finish
the wire inside usually last more than a lifetime if it isnt burned up by verry long startcycles the stuff that wears our is the stator and the brushes and the copper contacts on the solenoid .
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts Last edited by watahyahknow; 11-02-2009 at 09:23 PM. |
![]() Join Date: Aug 2008
I am running some sort of AC Delco gear reduction starter on my 383 stroker. I am not sure of the originl app, but it hasnt let me down in 5 yrs, even in 100+ plus Texas heat. I relocated the battery to the trunk, and when I did, I had some 3/0 welding cable from my dad who is a retired welder and ran that from the battery to the starter. I think that makes a big difference.
#13 |
I've had really good luck with the ac delco they cost more but I think you get what you pay for. If you order one for a 1970 i believe is the year they changed you'll even get a steel nose instead of aluminum.... bulletproof!
#14 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I'd disassemble the solenoid and turn the big copper washer over. That will make it ready for another 10 years of use. No sense buying a new solenoid or starter just because the contact washer is arced up.
#15 |
chrome ones start bestest
#16 |
when the starter is hot, it does not turn over or "acts" like it doesn't want to..... My battery is putting out over 12 volts while this is happening....
#17 |
called heatsink and i heared that before they usually solve that by using a remote ford solenoid mounted on the firewall
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#18 |
saw those posts.... hoping that a mini would be the solution...... will need to get this fixed soon... just drove about 15 miles today, side streets.. stopped at 7/11 and it would not start for a bit...
#19 |
Between Trucks...
x2
Beat it to fit, Paint it to match... ![]() |
#20 |
think a heatshield would solve it too it usually happens when running headers , thats not too expensive to try .
the heatsink thing is the metal round bar thats inside the solenoid heating up and sticking a bit making less contact than usual so the heatshield schould only need to cover the solenoid when the heatsink thing is realy bad it sumtimes helps to tap on the solenoid with a piece of steel (dont hit the battery hookups though or there be sparks flying )
#21 |
thought about a heatshield, but since the problem seems to have worsened quickly..... thinking it may be too late for that...
#22 |
I had the same hot start problem in my 71 with a 350 with headers. I went with the combo meal, new summit gear reduction starter with a heat rap plus the remote solenoid. So far so good.
#23 |
that is what it does rodger godding. i have been told it is the timing..but idk
#24 |
timing...... haven't adjusted time on this engine since first start up..... 3000 miles ago
..... had similar issues with same starter on last engine..... |
#25 |
![]() Join Date: Aug 2004
The GM mini starters work like a champ and you can get them anywhere. I think they came on the 97ish Vortec motors. Probably a bunch of others too. They do have specific bolts, so make sure to get them, the length is different from the old-school starters.
I mistakenly jumped my GM mini on my 454 with a 14ga wire and the wire didn't even get warm (was checking gear tooth clearance and not being careful). They don't draw many amps. Never had a heat problem either; manifolds or headers, up here or when I lived in hot-ass Dallas.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 11-03-2009 at 12:03 AM. |
