Old 11-02-2009, 09:25 PM   #1
CSoliz
Torn between 66 and 78
CSoliz's Avatar
84 3/4 truck parts that are usable for a 66?
My buddy has a 3/4 ton '84 at his buddys house. He told me I can go over there and take what I need from it. Now, I want to grab the lower control arms, spindles, calipers, power steering box, ps pump, ps hoses, idler arm, and the distributor. Brake booster is all ready gone
My questions to you are:
Will my list of grabs work on our trucks?
Anything else that would be a worthwhile swap for our trucks?
The truck is a 8-lug, can I buy 6-lug rotors for them and slap them on that spindle?
Am I forgetting something?
Any help and opinions are appreciated.
Thanks.
CSoliz is offline   Reply With Quote
Old 11-02-2009, 10:30 PM   #2
Bugeyev8
Bugeyev8's Avatar
Re: 84 3/4 truck parts that are usable for a 66?
I am pretty sure that the 3/4 ton spindles are different, the steering box will work with an adaptor
Bugeyev8 is offline   Reply With Quote
Old 11-02-2009, 10:50 PM   #3
CSoliz
CSoliz's Avatar
I have heard and read that we can use 73-87 lower control arms for disc brake swaps. If we can't use the spindles, which ones would you use than?
Old 11-02-2009, 11:20 PM   #4
sailed2japan
Jonny
sailed2japan's Avatar
Originally Posted by suicide 63
The recipe is
73-87
upper control arms any <c10-c20-c30>
lower control arms c20-c30
88-98
spindles for 1-1/4 inch rotors any exended cab will have them
rotors or a light dudy 3/4 ton they were six lug
upper and lower ball joints
outer tie rod ends
brake hoses
calipers
What makes this work is the 88 up ball joint presses into the 73 up 3/4 ton lower a-arm
Yuo will have to cut about a 1/4 inch off the new tie rod ends to get proper alignment.
Dont forget abought 88-91 square body stuff it all interchanges.
good luck
classic performance products has six lug rotors that go on 73-87 1 1/4 inch spindles about $120 for a pair.
This should help.
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 11-02-2009, 11:34 PM   #5
CSoliz
CSoliz's Avatar
It does. But, I thought I have read that the upper control arms are the same from 6x or so, thru 87??????
Old 11-03-2009, 01:01 AM   #6
CSoliz
CSoliz's Avatar
OK, after reading a ton of threads (again), I think I have the front figured out the front disc swap for 6 lug discs. Hre is what I came up with.
66 1/2 ton UCA.
Change LCA to 3/4 ton from the 84.
Get Spindles, Calipers, Upper and Lower ball joints, Outer Tierods; 1 1/4" 6 lug rotors; all from 88 & up.
Now, what parts do i need to upgrade to the power steering from the 84?
Old 11-03-2009, 01:03 AM   #7
SCOTI
SCOTI's Avatar
6X-72 have the threaded rubber-lined steel sleeve bushing. 73-87 have the press-fit rubber bushing (no steel sleeve). BJ's interchange on 6X-87 uppers so you just need the correct BJ for the spindle & it can be bolted on to any upper a-arm within those model years.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-03-2009, 02:07 AM   #8
Captainfab
60-66 Nut
The 6 lug rotors you need are for the 7200GVW 2500 series. IIRC the '88 & '89 are one part number and the '90 + are a different number. The spindles can be the from 1500 with the 1.250 rotors or the 7200GVW 2500. You will need some different inner tierods also, the ES2020's
As for the steering box, I sell the adapter plates. See the link in my sig.
66 1/2 ton UCA.
Old 11-03-2009, 09:08 PM   #9
CSoliz
CSoliz's Avatar
Very cool. Thank you. What exactly is GVW? I am guessing gross vehicle weight?
That is what I thought. Thank you for clearing that up for me.
Would it be wise just to take the whole steering assembly off the 84' or do I just need the pitman and idler arm? Or are they the same as the 66'?
Old 11-04-2009, 01:12 AM   #10
Captainfab
60-66 Nut
Yes that is correct. The 7200GVW is the light duty 2500 series (3/4 ton) which have the 6 lug discs in a 2wd version
I would switch over to the '84 steering linkage. It could be slightly heavier, plus that would make it a little easier to remember when the time comes that you need to replace worn parts.
Old 11-15-2009, 11:04 PM   #11
Hipper
Hipper's Avatar
another option is you can remove the complete front crossmember from the frame as a complete assemby with suspension. and it will bolt right up under your pick up. then you have the complete new suspension and steering. you only have to mount the steering gear and idler arm to the frame. This is alot easier with the engine removed because the engine mounts are bolted to this crossmember also.
71 GMC Long Bed, 454,factory everything, lowered, and shaved.
64 GMC Short Bed (great grandfathers truck)
65 Chevy 1 ton Dually a/c p/s p/b v8 auto
89 Jeep Cherokee 3" lift
79 MG Midget (My 7 year old vehicle)
29 Ford Model A Rat Rod (in the works)
86 pontiac fiero 2.5 manual18 year olds)
87 pontiac fiero SE 2.8 auto (18 year olds)
90 Mitsubishi eclipes turbo AWD (18 year olds)
69 BMW 1600 (wifes toy)
Hipper is offline   Reply With Quote
Old 12-24-2009, 04:47 PM   #12
CSoliz
CSoliz's Avatar
ok, one more question. I have 63-72 3" lowering springs for the front. If I was to swap to the 3/4 front end, would I still be able to use these springs?
Thanks.
Old 12-24-2009, 04:59 PM   #13
65gmc930
65gmc930's Avatar
Thanks.
yes the spring pockets are all similar
(62gmc910) I didn't notice that my son was signed in
65 gmc 930 292 4speed 700-18 duals 39k all original
65 chevy 10 long fleet parts truck
63 gmc 950 camperized bus 350 4spd 2spd axle
64 gmc 950 spare bus
53 gmc 1ton dual bus
79 gmc c20 short course offroad race truck 355 th400(www.wheel2wheel.ca)
65gmc930 is offline   Reply With Quote
