11-03-2009, 06:44 PM | #1 |
Need info: Cab brace extension, backing plates for rockers?
Hi, can I get some information from some of you? I am going to have a fellow weld up some bad spots on my truck, and he advised I needed the following:
Backing plates for rockers Cab brace extensions Now, looking at LMC just to figure out what I needed, I believe the rocker backing plates are called "Inner Rocker Panel", but I am not sure what the Cab Brace Extension is. Can any of you enlighten me? I don't know if that is the cab corner or not....might be but not sure. Also, would rather buy from a board member, so if you have the parts I need let me know prices and shipping to 42501 |
11-03-2009, 07:05 PM | #2 | |
Re: Need info: Cab brace extension, backing plates for rockers?
inner rocker panel http://estore.websitepros.com/126980...ATE/Detail.bok cab floor support front or rear http://estore.websitepros.com/126980...Categories.bok You can enter in cart and check shipping before you check out. just cancel or close page to cancel. You won't be charged we have to do that manually |
11-03-2009, 07:59 PM | #3 |
Mike I think he may be needing the A-post or B-post extension (cab extension) if he is replacing the inner rockers.
Kevin LFD Inc. |
11-03-2009, 08:10 PM | #4 |
11-03-2009, 08:45 PM | #5 |
Sorry guys, I should have been more specific:
All this is just patching, nothing is being replaced as such. The rockers are solid, but backing plates are junk. I am not sure about the other part....I think he is patching up what is there, but don't know for sure. I will call him tomorrow to verify, but I am pretty sure it is just a patch job, as the major components are still in usable shape. |
