Old 11-03-2009, 07:06 PM   #1
straight axle
straight axle's Avatar
Diesel to gas conversion
I have 88 Burb with a 6.2 that is toast I want ed to toss in a 350 that I have laying around, what is needed to perform this conversion???
straight axle is offline   Reply With Quote
Old 11-03-2009, 08:31 PM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Diesel to gas conversion
Anyone?
tvblazer78 is offline   Reply With Quote
Old 11-03-2009, 11:10 PM   #3
Daggar
Daggar's Avatar
Are we talking TBI 350 or a Carbed 350? Carbed 350 would be easier.
Carbed 350 would just be simple wiring and the fuel pump would be mechanical like the 6.2. Adjust or modify fuel lines and purge the tank and the lines and you should be pretty good to go. Then theres the drive train to contend with...
If you wanted to go Fuel Injected then you have a bit more work.
http://www.plowsite.com/showthread.php?t=56115
Some guy was doing this to a truck on there
1999 Chevrolet Suburban 2500 4x4 - 454, 4L80E and lots of other fun options
1967 Chevrolet C10 Longbox Stepside - Restored
1991 Chevrolet Suburban 2500 4x4 - 350, 4L80E - Not dead but severly crippled
1987 GMC Suburban 1500 - Now some retired guy's trailer hauler
1992 Lumina Z34 - I'll miss that PITA
Daggar is offline   Reply With Quote
Old 11-03-2009, 11:26 PM   #4
straight axle
Nope no FI just a basic carb fed small block.
Old 11-04-2009, 12:34 AM   #5
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Why do you want to convert it? It cost tons more to own a gasser.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 11-04-2009, 09:06 AM   #6
straight axle
The 6.2 is blown up, I have a 350 darn near ready to go in the garage, it is not a driver it is a toy lifted with 35's
Old 11-04-2009, 09:23 AM   #7
thirdstreettito
Resident of Here
I still dont understand. Diesel is way better than gas.
~Bradley~
Miss having a truck
Old 11-04-2009, 09:58 AM   #8
Jonboy
Slots go on anything!
I guess he might want something with more than 140 HP to move a lifted 'Burb with 35's.
I have never done the conversion personally, but I can't imagine it being too bad. You will need to pull the diesel fuel filters out of the loop, and clean out the tank really well. The trans in the truck will work just fine like it is, worst case you will need to swap out the TV cable and make sure you get a good bracket for it, to avout toasting the trans. The existing electrical should work, but make sure you run 12V to the distributor. I think the biggest hurdle you might find is is getting teh hydroboost P/S pump to swap. It seems like they are different from gas to diesel, so you might have to play with brackets a bit. Since people were putting gas engines in the old 5.7 diesels right and left, it shouldn't be too bad.
Old 11-04-2009, 11:06 AM   #9
68Timber
I know the pieces fit
68Timber's Avatar
I used to know a guy that did this swap and left the hydraboost in.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 11-04-2009, 06:11 PM   #10
wildwilly4x4
I have done this several times, but gone the opposite way. Take your diesel out and stick the gasser in it. If its a carbed motor, take the pink wire that goes to you fuel valve on the diesel, and stick it in the HEI dist. Everything else is pretty straight forward. If you want TBI, do the same thing, then get a tbi harness, ditch all of the emissions crap, hook the orange and black wire to a ground, then hook your pink/back wire to ignition hot, orange and red wires to battery hot, and ground it to the block and the body. Tan/white wire will go to your fuel pump. The orange and black wire that I said to ground will keep any emissions stuff from trying to come on, basically it will keep you from having a service engine light come on for emissions reasons. It just kind of tricks the computer.
wildwilly4x4 is offline   Reply With Quote
Old 11-05-2009, 01:22 AM   #11
thirdstreettito
Resident of Here
Why? My dads burb is fast with a 6.2. And if he adds a turbo it'll be twice as fast.
~Bradley~
Miss having a truck
Old 11-05-2009, 09:56 AM   #12
tvblazer78
Low & Fast!
tvblazer78's Avatar
If it was a newer Diesel I would say keep it, but the older ones are not as good as the new ones today and you can make a LS motor run just as good for not that much money..
Old 11-05-2009, 10:40 AM   #13
straight axle
an Ls engine would be a great swap but the funds will not allow it. Want one yes, afford one no.
Old 11-05-2009, 10:44 AM   #14
72freak
Rottenwood Garage Member
72freak's Avatar
I have one that the hydroboost is still intact. Works great!
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 11-05-2009, 04:39 PM   #15
wildwilly4x4
This is true, I run a Banks kit on my setup. It used to be in a crewcab shortbed 1 ton 4x4 that I built. Its not bigblock power w/a turbo, but its everybit as stout as a very healthy beefed up small block. I junked out the crecab rig and the drivetrain is sitting in my '72 stepside 4x4. 6.5L, Banks turbo, NV4500/NP205 t-case, 1 ton chevy axles w/3.73s.
Plenty of power for SMOKIN tires, and hauling a trailer, along with better than 20MPG!
Old 11-05-2009, 05:37 PM   #16
tvblazer78
Low & Fast!
tvblazer78's Avatar
Now that is cool..
But you do have to put some money into the older ones to make them run like the new ones.
Old 11-06-2009, 12:04 PM   #17
thirdstreettito
Resident of Here
My point is, diesel has the power/torque as a gas and gets twice the mileage. I have an 84, an 83 and maintain my friends 88. All 6.2's All with 20+mpg.
~Bradley~
Miss having a truck
Old 02-01-2010, 05:22 PM   #18
straight axle
tore in to this pig the other day found the problem, all the torque converter bolts had backed out, threw one through the inspection cover, and all flex plate bolts were sheared off. So I'm going to use the 327(it has trick flow heads twisted wedge heads) that I have for my 63 straight axle Chevy II, just going to swap the cam for a smaller one and use it. The Th 400 will get sent in for a rebuild and shift kit. I do not think you could pay me to keep a oil burner in this burb. This is a TOY used for mud runs and trail runs, the 6.2 is WAY to heavy and the "little" 327 will smoke it in the power department.
Old 02-02-2010, 12:49 AM   #19
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Nice looking burb. Gonna be sweet with that motor in it. Can't wait to see some pics of it
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 02-02-2010, 06:16 PM   #20
straight axle
Thanks, not bad for a freebie!The cam that is in the 327 is a basic .480/.480" 230/230* cam WAY to big for a burb. I'll either get ti re ground or go buy a Comp. hi energy 268* cam (.454" lift and 218* duration). That should make it much better for the burb.
Old 02-04-2010, 12:13 AM   #21
Cpnthrfan
does anyone know much about the 6.2. i have a 83 and i dont know much about them and cant seem to find much except it was ones i guess the newer deisel has caused some seals to leak.
Cpnthrfan is offline   Reply With Quote
Old 01-26-2011, 03:06 PM   #22
edflores
WTF. Mine did the same thing. Im going to try and replace the flywheel,And hope everything is ok. I drove mine like once a week as weather permitted then it just started making noises then is spit up one of the torque convertor bolts and dented some dudes car behind me on the freeway.
edflores is offline   Reply With Quote
Old 01-29-2011, 12:20 AM   #23
4pilgrim4
I always use red Loc Tite on torque converter bolts. Don't know if this is a common problem, but I just thought it would be a good idea.
4pilgrim4 is offline   Reply With Quote
