Old 11-04-2009, 01:18 AM   #1
BIGBLU 72
BIGBLU 72's Avatar
Single Wall Top Interior Lights....need info
when i put my rockers in i cut the plug that goes to the top to power the lights...awful mistake! where did this plug wire come from under the dash and is there any way to get another female end for the set up? any pics and info would really come in handy!
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 11-04-2009, 08:04 AM   #2
7d2k5
Re: Single Wall Top Interior Lights....need info
i just bought a 72 last fri & took top off sat , the plug you are talking about is still intact i will trace it to the firewall & let you know later today & try to send a pic
steve
7d2k5 is offline   Reply With Quote
Old 11-04-2009, 12:01 PM   #3
7d2k5
Post Re: Single Wall Top Interior Lights....need info
it is a white & orange wire that is held by a clip @ the dimmer switch & from there goes a about 4'' directly below fuse box where it has a black connector that hooks into a connector that comes straight down out of the fuse box
Old 12-21-2009, 09:23 PM   #4
Critter
Future TOTM Winner
Critter's Avatar
I'm reviving this thread...
So it sounds like the wire runs inside the rocker panel, or under the kick plate? Does it run up the inside of the B pillar or what? My 72 has both sets of holes along the beside so I'm not sure what top it came with (SPID says black hard top, but when I bought the blazer it had a white double wall). I ran a couple searches but didn't find anything with with much detail. Any body have any pics of where the wire was run or possibly direct me to a previous post.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
