Truckin' Krazy
![]() Join Date: May 2000
Shortbed upper/lower moulding set
This is a used set of upper & lower shortbed mouldings, I don't know if aftermarket or original, but they will clean up nicely, they have minor dings here & there & are not show quality, but would be for a very nice daily driver, the woodgrain on the lower trim is in nice shape & does not need replacing. Chrome is still shiny on both sets
Also including most metal clips $135 shipped for the upper & $150 shipped for the lower or $250 shipped for both sets Thanks, Tom
Dealer for: American Auto Wire Precision weatherstripping Dakota Digital Trim parts Carpets Truck World seat covers & Many others Chevy Parts locator in Mesa AZ! |
Truckin' Krazy
Re: Shortbed upper/lower moulding set
pics of upper trim
![]() Join Date: Nov 2006
im interested!
do you not have the plastic clips? but you do have most of the other ones? Last edited by duceducenine; 11-05-2009 at 12:20 PM. |
Truckin' Krazy
This trim has all the metal clips, I have the plastic clips also if you would rather have those instead.
Tom
so you have all the clips
or at least enough to make them work ...to install.....? |
Truckin' Krazy
I have all the clips you would need to install this trim, upper & lower, the metal clips were used if you had the trim originally & had all the holes drilled in the body, the plastic seems to be used when you don't have/want holes drilled, but still usually have at least 1 metal clip at each end of the trim.
Tom I'll be away from the board this weekend, but if you want them post here to hold them.
yeah i want them but could you do $200 shipped?
with all clips? |
Truckin' Krazy
I'll do $225 shipped & what clips did you want? metal or plastic?
i thought both were used and the plastic ones went on the doors
at least thats how my blazer was....so i would need both? right? |
