Fuel Solenoid Valve Help
I have an 83 Chevy shortbed 4x4 with a 6.2L diesel. It has the dual tanks and the solenoid valve for switching tanks has worked once since I got it going. The truck has sat for a long time so I'm hoping I have a bad connection somewhere. My question is, is there a fuse for that? I haven't had a chance to really investigate it because I'm working on replacing the engine in my diesel Burb. Any help will be greatly appreciated. Thanks!
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
