chevy runs deep
73 rear end
Ok guys I bought a 73 c10 front end and rear end so I can have disk brakes and 5 lug on my 69 Swb, I wanna keep my coils in the rear so i wanna know if I can take out the 5 lug axle of the 73 and slide them In my 69 rear end without any problems....
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: 73 rear end
No you can't. The later axles are 3/4 inch longer each. Your easiest bet it to get a set of axle saddles and a track bar from ECE or similar place and just run the whole rearend.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 11-04-2009 at 08:35 PM. |
chevy runs deep
Re: 73 rear end
Ok thanks that's what I'll do then
Re: 73 rear end
perches to mount the axel on the trailing arms are available you'd need them welded on plus a mount for the panhard bar// and easy conversion
![]() Join Date: Apr 2000
Re: 73 rear end
Thats what I did to my 70 to go from 6 to 5 lugs. Just swaped the axels from a 70 something but dont remember what year. Didnt even change seals or anything.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
Re: 73 rear end
They changed the rearends to the wider ones partway through the 70 year model run. Your must be one of the later 70 units that's wider. His 69 is definitely narrower.
Re: 73 rear end
Its been many, many years but now that you bring that up you are correct about the change in 70.
#8 | |
![]() Join Date: Jan 2009
Re: 73 rear end
I have a '70 (built in December '69) and how can I tell
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
