Old 11-04-2009, 09:38 PM   #1
boogie67
boogie67's Avatar
bolt hole problem
Can the head on a 350 be welded on?Somebody mess up the bottom bolt for the altanator.They tried to get it out and made it worse.
77 swb starting all over again.
boogie67 is offline   Reply With Quote
Old 11-04-2009, 10:19 PM   #2
hayhauler71
hayhauler71's Avatar
Re: bolt hole problem
Yes you can. Clean the broken bolt in the head than hold a nut next to the cylinder head with a pliers and weld the nut to the broken bolt. Than take a wrench to the welded nut and remove your broken bolt. You must get good penetration and fill the whole nut to make sure the nut does not break off.
hayhauler71 is offline   Reply With Quote
Old 11-05-2009, 01:01 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Or you can get the correct parts and install the alt on the drivers side.
Old 11-05-2009, 01:42 AM   #4
boogie67
boogie67's Avatar
I thought about that its going on a 76 chevy.I may have to do that.
Old 11-05-2009, 07:18 AM   #5
Longhorn Man
wel a 76 is supposed to be on the passenger side. I guess since this is on the 67 - 72 forrum, I assumed it was for a 67 - 72 truck.
Old 11-05-2009, 07:50 AM   #6
cdowns
cdowns's Avatar
if the bolt holes on the rear of the heads are ok you can switch the heads side for side and you'll have good holes in the front
Old 11-05-2009, 08:20 AM   #7
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Originally Posted by cdowns View Post
if the bolt holes on the rear of the hgeads are ok you can switch the heads side for side and you'll have good holes in the front
WOW good to know I didn't even know that was possible.....
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 11-05-2009, 12:53 PM   #8
nicolas72gmc
nicolas72gmc's Avatar
Hey Barney, where did you pick up the '69? Do you have some more pics of it? How did it go at CAT?
Nick
"Everyone has a plan, 'till they get punched in the mouth".........Mike Tyson
1968, GMC, SWB, Project
1972, GMC, LWB, Daily Driver, 383, headers, 2.5"/3" exhaust, 200r4, 3.5/5 ECE components.
1972, C/10, LWB, 350 vortec, th350
nicolas72gmc is offline   Reply With Quote
