![]() Join Date: Jul 2007
I have bought some of the brackets that mount on the trailing arms to relocate my rear shocks. Do I have to relocate my upper brackets and if so to where. I need measurements please. I bought these from another not the manufacturer, I think they are cpp brand. thanks in advance, Chuck.
Chuck 68 ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
#2 | |
Re: rear shock relocation specs needed
I may try just the lowers then. They came in today and are ece brand
thanks scoti!
low n' slo
![]() Join Date: Mar 2009
scoti, do you have pics how you relocated the top and bottom mounts?
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#6 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=359399
