Old 11-04-2009, 10:10 PM   #1
72YellowBird
Leak on front diff. area
I have a 98 GMC 4x4 that has developed a small oil leak on the RH side of the front diff. It is leaking around what looks like a eletric solenoid/housing. I don't have a service manual yet so I thought I would ask here fro some advise. How does this come apart? and is there an o-ring in there or does the solenoid have to be changed?? is the oil coming from the diff. becuase it doesn't look like gear oil.
72YellowBird is offline   Reply With Quote
Old 11-04-2009, 11:45 PM   #2
Re: Leak on front diff. area
It sounds like the actuator from your description.I`ve never had to service mine,so I don`t have any tips.I believe it`s pretty simple because they sell manual activators for the average Joe to install.I`m sure it`s an o-ring or gasket.What does the fluid look like?Is it way thinner than gear lube?
Old 11-05-2009, 09:58 AM   #3
72YellowBird
Yes it is thinner then gear lube. This the a separate housing that has a lighter oil in it??
