4 headlight rewiring?
I searched all over and couldn't find both setups. I wanted to do the upgrade with relays to make my lights brighter and also wire the lows to turn on with the highs.
Can anybody help me?
____________________________________ |
huh ???
Re: 4 headlight rewiring?
On 81-87 4 headlight systems, when the highs are on all 4 lights should be on...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
I have car A.D.D.
Here is the diagram the Joe231 updated off of Glock35ipsc info on his build thread. Post 620 (I think) here: http://67-72chevytrucks.com/vboard/s...350986&page=25
There is an improved version again post 631 http://67-72chevytrucks.com/vboard/s...350986&page=26
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. Last edited by Driveway Dreams; 11-05-2009 at 12:56 AM. |
Well I have that one down, how about the relay upgrade to make them brighter with this mod?
Jonny
If you want to wire up a realy simple take the wires coming from the switch and put them to the seleniod side of the realay and put the bulb wiring to the contact side. Add power and ground and you're done, sorry I don't have a schematic. does this make the headlights that much brighter?
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
#6 | |
Parts and more parts
The brighter is in the brand and wattage of the bulbs that you use. Also the direct wiring of the relays to the battery for power will give you a full 12 volts and not the degraded voltage that comes through the light switch.
Frank |
Is this the diagram to get the powerful headlight?
Adam M STX Designs Motorcycles | Choppers | Hotrods |
I am trying to figure out the same thing...how to wire both the lights together on 81-87 2headlight setup. but not run hibeams all the time.
Jonny
I like simple and would wire the low beams directly to an ignition switched power source. This would give you day time running lights and Low/High joint operation.
The diagram above works also, although it is not very precise. the idea is to take the switching power going into the high beam and bring it over to the low beam relay to activate it at the same time. The reason for the diode is so that power doesn't flow from the low beam to the high beam. This would cause you high beams to come on with your low beams.
