Old 11-04-2009, 10:58 PM   #1
blown luv
2wd to 4wd
ok guys I have a 86 chevy crew cab 3/4 ton. The truck is 2wd ,with 3" body lift and 33s. I wanna make it 4wd.I have found several 3/4 ton 4x4 suburbans in my area. Would the running gear"differentals,trans and t-case" fit correctly under my truck? Are the diffs the same width? Anything I should look out for?
blown luv is offline   Reply With Quote
Old 11-04-2009, 11:17 PM   #2
b454rat
Re: 2wd to 4wd
While the motor, tranny, t-case, axles and springs will work, the spring mounts/hangers won't. The truck hangers are taller than Burb's. Talking about the rears, the fronts are the same.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 11-05-2009, 07:49 AM   #3
74 C-30
Dually Pride
74 C-30's Avatar
Re: 2wd to 4wd
a 2wd rear spring hanger sits different than a 4x4 so you either need to replace the hanger, or make up for it with lift springs. dont forget to get a 4x4 steering box, and the different cross members for the transfer case and the engine.
If I have to explain, you wouldn't understand.
'74 Chevy C-30 350/4 speed/dually
'94 Ford Ranger
74 C-30 is offline   Reply With Quote
Old 11-05-2009, 09:46 AM   #4
b454rat
Re: 2wd to 4wd
I'm doing this to a 89 crew cab dually. I'll try to go front to back what I used/gonna use to convert it.
Front:
Diy4x B52 kit, comes with both hangers for the front springs.
http://diy4x.com/cart/index.php?rout...product_id=121
http://diy4x.com/cart/index.php?rout...product_id=114
I'm going with crossover steering, so need the 2wd steering box. If your not going crossover, you will need a 4wd box. Try to get a box of the same year, at least within a couple years so the lines will bolt on. Can't remember what years, but they changed the ends around and won't interchange.
The engine crossmember is still undecided yet. A 4wd crossmember won't fit, so gonna need to make something.
Front springs are junkyard 4" that I had from another truck.
Going with a divorced transfer case, so right now don't need to change the tranny crossmember. I might have to notch it to clear the front driveshaft, but won't know that till I get it all in there.
The rear suspension was probly the easiest. Since truck was a 2wd, the spring hangers were too short. Could use more lift, but would need at least 3" to make it match the front.
I used 1/2-3/4 4wd front hangers, and 1/2 2wd hangers for a homemade shackle flip. I used a 14ff from G30 van, needed the perches moved anyways, one of the reasons why I used those hangers, but the main reason is I already had them.
Here is some pics of what the stuff looks like on the truck. Need anymore, just ask, I can get much more. You can see in one of the pics the front suspension and rear axle.
