Using OEM AC Brackets with headers?
Can someone give me some guidance on mounting and OEM compressor with headers?
SWB 4x4 Collector
![]() Join Date: Jun 2001
Re: Using OEM AC Brackets with headers?
I am guessing you are talking about small block brackets. In this case, there are custom brackets out there, or you will have to cut the bracket that bolts around the factory manifold. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
![]() Join Date: Jan 2009
use a notched bracket
and longer header studs and spacers
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
sharp as a marble
![]() Join Date: Jan 2007
i am guessing that you are talking about the bracket that mounts to the rear of the A/C compressor. If you look in a jegs catalog, they will chow a bracket, that mounts to the header flange and give you a hole to hold the lower rear compressor mount. In process with a 70 Camaro, and needed the same thing.
Can we get some photos of all this please!!! I can't figure out where to attach the rear a/c bracket. Does it go to the manifold or what???
Old Skool Club
If I understand your last question, my 350 had a stud on the right side, at the front of the intake, which served to locate the rear of the original ac compressor. Here's a pic of the front of my engine before I pulled it from the chassis. I hope it will help.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 06-01-2011 at 06:34 PM. |
