spark plug for 383
74 350 block rebuilt to 383 stroker 10-1 compression,
I found a thread that stated with 10-1 comp and using accel shorty plugs to use Plug # 0414s and now I am using the ones from my old 350 motor wich are 576s, here are the differences and my questions are, will these be better for my 383, will they fit and what do these specs mean, thank you 0576s- ..460in reach/ heat range 6/ tappered 0414s- .750in reach/ heat range 4/ gasket |
![]() Join Date: Apr 2005
Re: spark plug for 383
You might want to put this in the Engine or High performance section. You'll probably get a better response.
R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
