disk brakes
I have a quick question are these dick brake conversion or wat are they http://www.blackbirdscustomtrucks.com/index7.html if you go down to were it says 1972 and older. I was curious wat it was.
Re: disk brakes
Dick Brake conversion???
I think you need to clarify the question. Every product on the page is a disc brake conversion kit.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= ![]() Douchebag Racing: Runs Fine all the Time |
Re: disk brakes
yes disk brake conversions.......are they that cheap .........dont they run for a bit more.....so the kits they sell is all i need to do a diskbrake conversion on my truck.
Re: disk brakes
DISC brake conversion.
That is an average price, I've seen some cheaper and there are higher priced ones for better performance. Do a search and you will see what others have bought for DISC brake conversions. The ones you called out aren't the right ones. CALL them if you decide to buy the kit from them to make sure you buy the right kit.
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: disk brakes
This is the first 100 threads on this subject.
Look here: http://67-72chevytrucks.com/vboard/s...archid=1366497
Happy to be here
![]() Join Date: Mar 2000
Re: disk brakes
Yes, those are disc brake conversion kits. Blackbirds is known for offering a economical kit that can purchased as a package or just buy the brackets and add your own components.
Re: disk brakes
We're just an option. Our kits are meant to be bolt on and go. No guess work or tracking down parts.
I'm always on the board if you have any questions.
Support The Board |
#8 | |
Re: disk brakes
Any possibilty of a group buy? Thanks
#9 | |
Re: disk brakes
Rotors are chevy 3/4 ton rotors and 73up 1/2 and 3/4ton chevy non ebrake calipers or with caddy ebrake calipers..
Support The Board |
Re: disk brakes
I have a 1969 Gmc 3/4ton 2wd with rear leaf springs. I have drum brakes all the way around and would like to have front disc brakes...What package do you suggest...
drink2mny.thanx |
Re: disk brakes
Well, as for the front one of your better options would be to get 71 chevy 3/4 ton 2wd front parts and A arms. There is a little bit of work to be done to go disc all around. You have to be ready for it.
. You can give Randy a call if you are having a hard time getting the parts. 509-534-5219 As for the Rear kit, it just depends what you have eaton or Dana 60 presuming its stock. I'm guessing eaton.. You can get that straight through the site or see what Randy can do for you.
Support The Board |
Re: disk brakes
So if I go wit the rear disk brake it will just be a bolt on kit ......and wat exactly do i need....thanx for the help
#13 |
Re: disk brakes
Yes. the kit is a bolt on kit with instructions.
I forgot to add above, with going from drum/drum to disc/disc you should also get a 71/72 3/4 booster master cylinder and proportioning valve.. You will most likely put new brake lines out back and get a set of short rubber hose brakelines to go from the solid lines to the calipers.. Which we sell as well.
Support The Board Last edited by drink2mny; 12-18-2009 at 07:14 AM. |
#14 |
Re: disk brakes
ok thank you....I should be ordering soon...however is it a 71/72 3/4 booster master cylinder and proportioning valve i need or a 71/21 because u have written 71/21
#15 |
Re: disk brakes
edit above
Support The Board |
