Old 11-05-2009, 04:17 PM   #1
mtdave2
newly minted old timer
mtdave2's Avatar
vibrations with rpm.
I have an off rithmic vibration at 2700 – 3200 rpm, but only while driving at over 50 mph or so.
Vibration goes away, when shifting to higher gear, but keeping mph the same, so I don’t THINK its drive line. It would be connected to mph if it where, and this is rpm
Will not do the vibration while in park/neutral in drive way when reving to the rpms. the motor does sort of vibrate, a differ ant constant type, at around 3k rpm though
Stated after I had the trany rebuilt. Trany man has no ideas. Drive line guys as well.
hum
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 11-05-2009, 05:19 PM   #2
cdowns
cdowns's Avatar
Re: vibrations with rpm.
was the driveshaft taken apart to put nu ujoint in if so maybe you're out of phase
Old 11-05-2009, 05:28 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
Is the driveshaft the right length? If you have done some work onthe shaft or changed out the tranny, then there is a chance that the length is a little too short for the spline on the tranny and you have a vibration.
Frank
piecesparts is offline   Reply With Quote
Old 11-05-2009, 05:35 PM   #4
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Could it have something to with the gear vendors install?
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 11-05-2009, 06:17 PM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
Possibly the Converter or the clutch fan. Make sure they didn't crack the cap when installing the trans.
dwcsr is offline   Reply With Quote
Old 11-05-2009, 06:25 PM   #6
SCOTTMO
powdercoater
Check to see that the trans is not grounding out on the crossmember also
you might want to remove the drive shaft and rotate it 180 deg.
SCOTT
SCOTTMO is offline   Reply With Quote
Old 11-05-2009, 10:56 PM   #7
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
This kind of problem is very difficult to solve because it can be any number of things. One good way of diagnosing it is to have someone in the cab run the gas pedal while you go over everything with a stethoscope.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 11-05-2009, 11:06 PM   #8
Pont406
My truck had a vibration at 50 mph and up. I also thought that it was motor or trans. My buddy ran it on the chasis dyno and it didn't vibrate at all. I rebuilt front end and install new tires. All vibration is gone. Do you have a chasis dyno in your area? I don't know what's a rate there but here it's around $80-90 for 3 pulls. AT the same time you will know if your air/fuel ratio and a lot of other stuff is right. Might help to figure out your power loss also.
Pont406 is offline   Reply With Quote
Old 11-05-2009, 11:18 PM   #9
Sammy
Torque converter bolts, tranny mount could be any of these. The out of phase D/S is also another good suggestion even a dry U joint.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 11-06-2009, 02:03 AM   #10
mtdave2
mtdave2's Avatar
good info thanks...
more info for you..
i installed the gearvendor, and had the drive line done and redone, see other post! .. no vibrations, all was well.
there were stickers put on the drive lines to mark where they go together, so that isnt the prob, though ilike the idea of rotating it 180, ill try that.
had the trany rebuilt, that is when the vibration started. so my number one thought is the converter. though, i would think id have the same prob in park.
69 k10 Suburban
Old 11-06-2009, 02:05 AM   #11
mtdave2
mtdave2's Avatar
clutch fan? you mean the one on the front of the motor?
69 k10 Suburban
Old 11-06-2009, 04:48 AM   #12
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
This could also be that the front tires have uneven wear cause by hard braking. Have you smashed on your brakes lately, You could ruien a new set of tires by slamming on the brakes or a hard stop enough to cause the skid this causes the vehicle to viberate at a certain speed and if you speed up or decelerate it goes away..
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 11-06-2009, 11:06 AM   #13
mtdave2
mtdave2's Avatar
if it were tires then i shouldnt go away just by shifting into over drive..
and they are nice shiney new tires too =)
69 k10 Suburban
Old 11-06-2009, 11:16 AM   #14
tim21391
tim21391's Avatar
a friends driveshaft didnt look to be bent but when he took it somewhere it was off my like.002 or .02 i cant remember but it wasnt visable to the naked eye and it kept vibrating the rear seal out of the tranny... just my two cents..
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 11-06-2009, 11:24 AM   #15
mtdave2
mtdave2's Avatar
i did a 180 on the drive line, see what happens. doesn’t make sense to me though. the key here is the vibration is with RPM not MPH. when put into neutral it goes away immediately.
69 k10 Suburban
Old 11-06-2009, 11:38 AM   #16
mrh33916
Project '67 454
mrh33916's Avatar
Did you check the bolts holding the transmission bellhousing to the motor?
mrh33916 is offline   Reply With Quote
Old 11-06-2009, 12:53 PM   #17
mtdave2
mtdave2's Avatar
no i have not.. never even crossed my mind, but i will.. thanks
69 k10 Suburban
Old 11-06-2009, 02:29 PM   #18
Tkmadone
I have the exact same issue. I removed the clutch fan, the engine mounts, and had the drive shaft redone with no improvement. I'm going to replace the tranny mount next.
Tkmadone is offline   Reply With Quote
Old 11-07-2009, 06:23 AM   #19
RustyParts
RustyParts's Avatar
I would remove the bolts from the torque convertor and rotate the convertor on the flywheel one bolt hole and see if the vibration changes.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 11-07-2009, 01:36 PM   #20
CCCC
CCCC's Avatar
Some very good suggestions from these guys, and if you do as RustyParts suggests (good idea), be certain to check the flex plate for tightness and especially for cracks/incipient breakage. This can cause the type of vibration you are chasing.
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 11-08-2009, 04:31 PM   #21
mtdave2
mtdave2's Avatar
i took the camper on a short drive, and i did some more tests.
same vibration at the same rpms, shift in od, and its gone. finally have enough clear highway to get the rpm back up in od.. has the vibration too.
also, i put in neutral at the top end of the rpm vibration, of course they stopped when it went to an idle. then i revved it up to the vibration range, and i did get some vibration, though not as pronounced.
it is defiantly forward of the gearvendor.. so trany, converter, flex plate, or something in or on the engine.
would a cam retarded a tooth or a slightly flatted cam lobe cause this?
ill get a new clutch fan and put it on while im taking the timing chain cover off to have a peak.
69 k10 Suburban
Old 11-08-2009, 04:59 PM   #22
k5hart
k5hart's Avatar
I had a problem similar to that when my driveshaft was too long. It was pushed all the way in to the tailshaft which was putting it somewhat in a bind.
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel
Charleston, South Carolina
k5hart is offline   Reply With Quote
Old 11-08-2009, 05:35 PM   #23
cduster
Harmonic balancer? Just a thought
Good Judgment comes from experience.
Most experience comes from bad judgment.
cduster is offline   Reply With Quote
