Old 01-20-2003, 12:44 AM   #1
Stano
Stano's Avatar
Leaking speedo drive, TH-350
I need to know how to seal a speedo drive in a TH 350. It is driving me crazy. Put new O ring on and still leaks. Also what is the tooth count for a speedo drive gear for 3.73 rear end? I need that too, the one I have in is for 2.73's and its way off. It was all I had at the time. Any help is greatly appreciated folks.
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80
Nice ride 67 Chevy C-10 LWB Built 350 TH-400
Wifes ride and family rig:
2001 Furd Expedition 5.4 Liter
Kickin back in Rolla,Mo. USA
"Do the thing you fear most and the death of fear is certain" Mark Twain
Stano is offline   Reply With Quote
Old 01-20-2003, 02:21 AM   #2
gman
Stano,
ttt
I'll be watching this post. Mine is doing the same thing and I don't know what to do to get it to stop.
72 Chevy SWB Custom Deluxe K10, 350/SM465, PS, PB, Fact. Air
2000 Harley...Wide Glide
gman is offline   Reply With Quote
Old 01-20-2003, 02:40 AM   #3
Stano
Stano's Avatar
Watch away gman! The truck hasn't been out of the garage since Thanksgiving and I knew then it had some seeping going on. Today I was putting my brace on for the power brakes I dropped a bolt and went around the side to retrive it and noticed gobs of tranny fluid on the floor under the truck. The only places I can see fluid coming from is the speedo drive and a slight drip out of the rear seal which were resealed early last year with less than 1500 miles put on it. I know I did it all right cause I did everything the same way I've done for years and have some of my and my dads vehicles that have 10,000's of thousands of miles and no leaks. Maybe I got crap seals or something, but it has to be fixed none the less. Hope someone can tell us the trick that some ol man told them when they were young or something.
Old 01-20-2003, 03:24 AM   #4
magoo72
magoo72's Avatar
i DID have the same problem. i changed everthing trying to stop it. the final thing i changed was the gear itself. that stopped the leak for me. i checked the o.d. of the gear i had verses the gear i put in and the one that was leaking was smaller,it may have been worn. but i no longer have the problem.
let me know if it works for you
mrmagoo
magoo72 is offline   Reply With Quote
Old 01-20-2003, 08:36 AM   #5
70c10
67-72 Addict!
70c10's Avatar
You need a new bullet to stop the leak. Go to a tranny shop and buy one for a few bucks. I don't know how cold it is where you are but it's cold here so I recently paid $40 to have it changed. No more leak!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-20-2003, 08:57 PM   #6
gman
70c10,
Sorry, but what do you mean by a bullet?
Old 01-20-2003, 09:28 PM   #7
Dropt72Shortbed
Dropt72Shortbed's Avatar
Originally posted by gman
Stano,
make me the third!
mine spills alot..
going to be swapping to 700r4 so im not too concerned now though
Dropt72Shortbed is offline   Reply With Quote
Old 01-20-2003, 09:51 PM   #8
kaycee
kaycee's Avatar
SILLYCONE
will work.I also went and got a good rubber o-ring from Chevy and that seems to have done the trick so far 10k miles later and no leak.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 01-20-2003, 10:14 PM   #9
Fred T
Cantankerous Geezer
Fred T's Avatar
Stano - When you replaced your rear seal did you put a redi-sleeve on the shaft? If a groove is worn in the shaft it will leak again.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 01-21-2003, 12:23 AM   #10
Stano
Stano's Avatar
No groove on the shaft or yoke, so I don't think that is the prob I'll check again though. I do need the proper drive gear for my speedo to be right and I will try new o-rings again too! I may have messed it up installing somehow! Thanks If anyone else has more ideas please pass em on. I am always willing to learn something new.
