Old 11-05-2009, 06:15 PM   #1
hobsiscool
Rocker Stud Pulling Out...HELP!
I have a couple of rocker studs pulling out of my 4.1L Inline 6...what can be done? Is there anyway of putting new regular studs in so that they'll hold, or will the holes need to be drilled and threaded studs put in? Help me out please!! I've had it apart and put back together like twice and the studs keep backing out...We had pondered lock tite on them but I seriously doubt this is a permanent or even temporary fix....I really need my truck back but it keeps being one thing after another...is it worth fixing, or should I just replace the head?
hobsiscool is offline   Reply With Quote
Old 11-05-2009, 08:54 PM   #2
JMac11
JMac11's Avatar
Re: Rocker Stud Pulling Out...HELP!
You can knock them back down flush with the others and then drill the head and stud to place a 1/8" roll pin thru or they make or used to make a stud that you could thread the old hole and install with lock tight. I never used the threaded stud but did see them in machinist engine parts catalogs ten years ago when I used to do such work.
JMac11 is offline   Reply With Quote
Old 11-05-2009, 08:58 PM   #3
cableguy0
if this is a stock motor and doesnt have a high lift cam just pin the stud. heres what you need. http://www.mr-gasket.com/ProductDeta...minselection=1
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 11-06-2009, 08:44 AM   #4
XtremeBowtie
XtremeBowtie's Avatar
In the past we've always took the heads and had screw in studs installed. It was always pretty cheap. If you have a decent Bridgport, you could probably do it yourself.
First and Foremost: Thank you God for my Salvation! I pray that others will seek your Son, Jesus Christ!
My 63 Double Dropmember Build "Project Sub-Zero": http://67-72chevytrucks.com/vboard/s...42#post5050342
XtremeBowtie is offline   Reply With Quote
