11-05-2009, 07:59 PM | #1 |
fuel gauge wire on 87 tbi
ok i relized that i dont have a wire for my fuel gauge!!!!!! i have the fuel pump plug to the relay but where does the fuel gauge wire go on a 87 r10 sending unit???
11-05-2009, 10:11 PM | #2 |
The One And Only !!!
Re: fuel gauge wire on 87 tbi
A little more detail into what your doing may help......
Are you replacing the sending unit and find no provision for the fuel gauge ? If so, I just ran into the same problem installing a 86 tank in my 97. I bought a 86 sending unit but it wasn't right (not like the old one out of the 86), I found there are a couple different style sending units and couldn't find the proper one in a aftermarket. The local dealer has the right one but I'm not shelling out close to $400 for a bare (no pump included) sending unit.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
11-07-2009, 12:00 PM | #3 | |
11-07-2009, 09:08 PM | #4 |
You should have three wires coming off the sending unit, A gray and purple in a connector plug and a black with a eyelet that goes to a grounding point (frame).
The gray wire powers the fuel pump and the purple activates the fuel gauge.
11-08-2009, 08:59 AM | #5 |
oh so i need to look at some schematics
11-08-2009, 10:07 AM | #6 |
I have OEM electrical manuals for an 87 , what do you need? Fuel sender wiring only? or the whole run of the wiring front to back...
Let me know... Desert Last edited by Desert1957; 11-08-2009 at 10:07 AM. |
11-08-2009, 03:54 PM | #7 |
11-09-2009, 07:07 AM | #8 |
ok,
I will post it up later today.... Desert |
11-11-2009, 11:04 AM | #9 |
Sorry its been a few days since I told you I would post this...
Here is the wiring at the tanks and fuel senders , This should give you a start. It shows color codes and locations in the connectors Fuel tank selector on dash if you have dual tanks Not sure if this is what you need, If you need the dash cluster wiring let me know Desert |
