Old 11-05-2009, 08:11 PM   #1
samwise68
FarmBoy.
samwise68's Avatar
Removing Heater Core?
Hey all,
Winter's around the corner and my heater core is leaky. I have a replacement one out of one of my other trucks, but I ran into a hitch this afternoon - how do I get the heater core/fan assembly out?
I mean, yes. Take the bolts out, etc. But, there are some clearance issues with the inner fender and the bottom bolts.
Please don't tell me I need to take my inner fender out, just to remove it...
Anyone have any tips or tricks? I'd really appreciate it.
Thanks in advance.
-Sam.
1969 GMC C1500. long fleet.
307. 3 on the tree. 3.07 gears.
Oliver green. Bent and bruised. Daily Driver.
Screw patina... it's a beater...Beaters are cool.
my build thread - Project Homebrew:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993
samwise68 is offline   Reply With Quote
Old 11-05-2009, 08:20 PM   #2
kwmech
Re: Removing Heater Core?
Take your inner fender out
Old 11-05-2009, 08:28 PM   #3
JimKshortstep4x4
Do you have AC or not as the AC heater core is a lot easier to replace compared to the standard heater.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 11-05-2009, 08:51 PM   #4
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
As "kwmech" said....remove the inner fender.
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 11-05-2009, 09:12 PM   #5
cdowns
cdowns's Avatar
it's a great weekend project// take out inner fender clean t up spruce it up with a can of paint clean up the exposed framerail and the side of the engine block change the heater core then button it all back up/ heck you could also take off the hood hinge clean lubricate and paint it too
Old 11-05-2009, 10:57 PM   #6
Chevyntytwo
While your at it think about a replacement blower motor. Inexpensive and worry free for years to come.
72 k20 Cheyenne Super 350 Turbo 400 Dana 44 Front / 60 Rear NP 208. 315 70 17 Hummer H2 wheels. Black.
Chevyntytwo is offline   Reply With Quote
Old 11-05-2009, 11:25 PM   #7
Sammy
You can remove the bolts on the inner and slide it around without removing if you like. Also I think I removed the R/H hinge and used a 2X4 to hold the hood to get to that 1 bolt.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 11-05-2009, 11:46 PM   #8
Smallz72project
Smallz72project's Avatar
I just had to do this myself on my truck. I robbed the assembly off my 72 for my 67. I did not remove the inner fender although you will need to unbolt the hood hinge so you can swing it out of the way enough to clear it all. The only one that you cant reach isnt actually a bolt, its just a thin sheet metal style nut thats pressed, if your not super worried about it you can unbolt all the other ones you can and then just wiggle it gently until that nut pops off, now you wont be able to reinstall that nut with out taking the inner fender out. The correct way would be inner fender removed, but if you are in a hurry and just need it done and plan on going back in at some point...its an option...I only used this method for removal...installation onto my 67 is with the inner fender removed. Also once you get it off...dont get too anxious and pull too hard.....the flapper door is attached just on the other side and will prevent you from removing it completely...just need to swing it out enough that you can see it and get on the keeper with a pair of needle nose pliers. Good luck!
- 1967 Chevy C10 shortbox
- 1984 Chevy K10 "Mater"- SWB 305 manual, retired sheriffs truck, Current Frame Off Project
- 1986 Chevy K10 LWB 350/350 Daily Driver/project
Smallz72project is offline   Reply With Quote
Old 11-06-2009, 10:53 AM   #9
samwise68
FarmBoy.
samwise68's Avatar
Alrighty then, at least I was totally missing an obvious alternative solution.
Thanks guys, I'll look into it this weekend. For now, I just bypassed the heater core, so I won't be getting fumigated with antifreeze, haha. Good thing I don't mind driving without heat for a few days, should I have to.
Thanks again!
-Sam.
Old 11-06-2009, 12:34 PM   #10
VetteVet
Msgt USAF Ret
VetteVet's Avatar
This from the FAQS
http://67-72chevytrucks.com/vboard/s...ad.php?t=69812
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 11-07-2009, 12:06 AM   #11
WyoGMC
WyoGMC's Avatar
I just replaced my heater motor recently. On the subject of not getting too excited to pull off the heater box because of the flapper wire. You can pull the rubber grommet from inside the cab and pull off the cable before you try to pull off the heater box.
I wanted to to put in a new heater core while I was working in the area. But the checkbook wouldn't let me. It is a real good idea to change out the heater motor while you have it apart. Nothing worse than having to do the same work twice when you could have taken care of it the first time. Plus get new gaskets too.
68 GMC
91 GMC ext cab
05 Dodge Ram SRT-10........gone but not forgotten
WyoGMC is offline   Reply With Quote
Old 11-07-2009, 12:46 AM   #12
sameyrasmea72
sameyrasmea72's Avatar
Originally Posted by samwise68 View Post
....... I have a replacement one out of one of my other trucks, .......
-Sam.
This is not a difficult job to do, but it is not simple either. I would try to get a brand new core if possible, or you might have to do the change all over again in a couple years. a new one should last the life of the truck nearly. I don't think they cost much at a parts store. If not a new one, take the one you plan to put in there to a radiator shop and they can pressure test it for you.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 11-07-2009, 01:57 PM   #13
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if the blower motor is not making noise, i would leave it alone. With the total lack of quality in parts store electronic stuff these days, your old motor will more likely than not live longer than the replacement junk. Plus, it is super easy to swap in a new motor in compared to a heater core.
If the funds are there, i would consider a new core over a used one off a parts truck.
Old 11-07-2009, 04:00 PM   #14
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
I'd suggest installing a new blower seal while your at it.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 11-08-2009, 11:14 PM   #15
lok-dawg
lok-dawg's Avatar
About to tackle this exact same install. . . Will definitely be buying a brand new core though.
'72 Chevrolet C10- Deluxe/5.7/Short Fleetside
'02 Chevrolet Tahoe- LT/5.3/4x4
'13 Ford F150- XLT/5.0/SuperCrew/4X4
'14 Subaru Impreza- Limited/2.0/Sedan/AWD
lok-dawg is offline   Reply With Quote
