Old 11-05-2009, 10:26 PM   #1
Gmelahn
Gmelahn's Avatar
Can you find the vibration??? (UPDATE)
I would like to start off saying that this is my first post on this forum but I have been here for a few months now. What a great site!!!
I have a 1972 K10 new motor(stock w/ rv cam), a 4" Rancho lift, rebuilt posi 3.73, turbo 350, np203. Truck sat for a while(was my dads) but has a rebuilt transmission. I also just had the driveline straightened and balanced, the rear-end rebuilt, the transfer case had the coupler and transfer case spline replaced and new tires 33x12.5x15 with less than 200 miles.
Problem:
I get a bad vibration at freeway speeds, the vibration is constant but is strong for a few seconds then it gets lighter. The vibration has a consistent tempo that lasts until I am under about 45-50 mph. There is also noticeable vibration(while not as strong) under some accelerations. Also when I let off the gas and then reapply the gas quickly there is a noticeable clunking coming from the transfer case/transmission. I can control the clunking by feathering on and off the throttle.
The engine was just checked out by our Mechanic today and he said the vibration is not engine related. He did however recommend new transmission and transfer case mounts, which are now on order.
I have searched as many different combinations of words to try and figure out what else the vibration could be, I have had a lot of good tips but I am sick of throwing money at this problem.
What should I look for, Torque converter? Fly wheel? Wheel bearings? PLEASE HELP!!!
Thanks,
Gmelahn is offline   Reply With Quote
Old 11-05-2009, 10:40 PM   #2
2tons of fun
Re: Can you find the vibration???
ujoints.
who did the rear end?
new or old diff?
new or old bearings?
how much lift?
driveline angles?
2tons of fun is offline   Reply With Quote
Old 11-05-2009, 11:33 PM   #3
Rack Man
My first thought was u-joints too...
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 11-06-2009, 09:48 AM   #4
LONGHAIR
You stated that this truck has a NP203 transfer case, it is still "full-time"? or has it been converted?
There is a chain drive that works the front drive shaft, slack there can make all kinds of noises and/or vibrations.
This could very well be your "clunking".
There is also a fairly thin stamped drive ring that can cause problems in there too.
You didn't say if you could feel this vibration through the steering, but if so....I could be front axle-joint stiffness. This is very common too. A thorough front end servicing is probably in order anyway.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 11-06-2009, 10:46 AM   #5
Gmelahn
Gmelahn's Avatar
Thanks guys,
U-joints were replaced with Spicer when the driveline was straightened and balanced by a driveline shop. The driveline shop wants me to bring the truck back so they could check the driveline angles.
Bearings need to be checked..
The Transfer case is a part time transfer case....
The rear end was rebuilt by a transmission/drivetrain shop owned by my fathers buddy.... I'll have him check the rest of the transfer case as well.
The vibration is not really felt through the steering(at least not primarily).
Just had the front ball joints checked and one replaced. I guess I could check the rest of the front end.
I will be replacing the mounts today, I'll keep everyone updated thanks for your replies! I hate chasing down problems by throwing money at it. I need a mechanic that can actually diagnose problems. haha
Garrett
Old 11-07-2009, 02:53 AM   #6
Gmelahn
Gmelahn's Avatar
So while I didn't get the opportunity to replace the mounts today, I found something else out that may be causing the problem. I was under another K10 we have and I noticed something was different, something was missing on my truck. Here is a pic, can you tell me what I'm missing?
Old 11-07-2009, 02:56 AM   #7
2tons of fun
the unecessary portion of the cross member?
the unecessary strut bar from the tcase to the bell housing?
Old 11-07-2009, 10:18 AM   #8
Rack Man
Torque Mount....
Old 11-07-2009, 10:51 AM   #9
Gmelahn
Gmelahn's Avatar
winner! winner!
so now my question is.... will this cause the vibration I'm experiencing? or is the the cause of the clunking I hear?
And an even bigger question.... Where can I buy one? I have looked everywhere!!!!
Thanks guys
Old 11-07-2009, 11:52 AM   #10
2tons of fun
no.
Old 11-07-2009, 03:13 PM   #11
Gmelahn
Gmelahn's Avatar
Originally Posted by 2tons of fun View Post
no.
"no" this wont cause the vibration? or "no" you don't know where to find one?
Old 11-07-2009, 03:25 PM   #12
Gmelahn
Gmelahn's Avatar
This is what I'm looking for...
Old 11-07-2009, 05:02 PM   #13
LONGHAIR
Though I would not call it "un-necessary", the lack of that mount will not cause your vibration.
45-50 MPH also points to wheel balance. Have you done anything about that? Try swaping them around to see if it changes anything?
Old 11-07-2009, 05:24 PM   #14
Gmelahn
Gmelahn's Avatar
Well I was hoping that would be the problem. I had the wheel/tires mounted and balanced a month ago but I'll switch them around and see if that helps.
Also I found out its a 205 Transfer case, kinda weird though because the speedo cable is on the drivers side?????
Old 11-08-2009, 06:44 PM   #15
2tons of fun
so which is it, a 203 or a 205, from your pic there is now way to tell.
the mount you posted is a 205 mount but you could use it on a 203.
a 203 uses a rod that mounts to the same to bolts then runs all the way up to the back of the bell housing.
and yes, no it wont make it vibrate and no i dont know where to find one.
Old 11-08-2009, 07:16 PM   #16
Gmelahn
Gmelahn's Avatar
My Dad who I bought the truck from says its a 205, "all gears inside" is what he said. Funny thing.... the speedo cable is on the drivers side. I thought only the 203 had the speedo cable on the drivers side. I'll get a pic tomorrow.
I already bought a mount from one of the other members. But I still need to chase down this vibration. I work weekends but tomorrow I will rotate the tires and I have an appointment with the mechanic who worked on the trans transfer and rear end.
I'll post more when I find out what the problem is.
Thanks,
Garrett
Old 11-09-2009, 06:57 PM   #17
Gmelahn
Gmelahn's Avatar
Re: Can you find the vibration??? (update)
So the transmission/drivetrain Mechanic said it was not drivetrain related and to look at the flexplate. I also need new exhaust and he said that could be a source of the vibration because the hangers were all trash and metal on metal.
On another note I took a picture of my 205 and noticed that where the speedo cable enters the transfer case is on the wrong side. First how is this possible and second woud this cause any of my problems???
Old 11-09-2009, 07:19 PM   #18
84 400
Sb 400 club
84 400's Avatar
Don't quote me on this but I think the tail cone could be rotated?? My truck has a factory NP203 and does NOT have the tourqe arm. It looks like you definatly have a np205 tho because it has the lower drain plug which my np203 does not have.
Wish i could be more help
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 11-09-2009, 07:21 PM   #19
Gmelahn
Gmelahn's Avatar
It is a np205 say so on the metal 1"x2" tab. plus the mechanic said its all gears inside. Would this cause a vibration? Should I turn it around asap?
Old 11-10-2009, 01:38 AM   #20
2tons of fun
no it wont and some of them are on the d side, not a big deal.
with a full pic now you can tell its a 205, the small round metal cover in the middle is the idler shaft retainer and is only on the 205.
you CANNOT rotate the housings because the goofy bump on the upper right side of the housing is the shifter rail cover/seal and you piss oil out.
Old 11-10-2009, 02:09 AM   #21
Gmelahn
Gmelahn's Avatar
the transmission guy also said the transfer case should run tranny fluid?? From what I have read this is WRONG! 10w40 is what should be in there...
Old 11-10-2009, 02:20 AM   #22
2tons of fun
or 80-90
you can run whatever you want, the atf isnt supposed to be as protective fo rthe gears but it was spec'd in dodges.
Old 11-10-2009, 02:21 AM   #23
2tons of fun
fwiw i have always ran 80-90 + mud and water.
Old 11-10-2009, 02:23 AM   #24
Gmelahn
Gmelahn's Avatar
haha, I think I'll change it. There is a slight noise when i let off the the throttle and then get back on it lightly, the trans guy said it normal play in the gears with big tires.
Any experience with that?
Old 11-10-2009, 04:31 PM   #25
Oilbrnr
Oilbrnr's Avatar
Has the pinion angle been ruled out yet?
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
