11-05-2009, 11:44 PM | #1 |
Future TOTM Winner
Those who have installed Vintage Air please look
I have searched but cannot find a solid answer to this. When installing a vintage air kit into a 72 that ORIGINALLY had factory A/C, what all "vents" can be welded up. I'm pretty sure that the kick panel vents by your feet along with the old fan hole on the firewall are no longer used. Also, what about the cowl area where the original fresh/recirculate flap was, can I weld that area up to keep leaves and dirt from gathering down there again? I think the answer to all of this is YES, I am just hoping to hear from someone who has actually done this conversion. Thanks.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
11-06-2009, 08:41 AM | #2 |
Spanked once
Re: Those who have installed Vintage Air please look
Yes but, You could use a screen under the cowl because the other side is wide open too.
The ole 350 budget build. |
11-06-2009, 09:27 AM | #3 |
Future TOTM Winner
I actually do have a nice set of those screens that I found on my parts truck. I was considering welding up the other side to match so we would never have that rust problem again. Any thoughts?
11-06-2009, 09:41 AM | #4 |
Between Trucks...
I would just run the screens. You'll also be able to keep an eye on it, if it's left open.
Beat it to fit, Paint it to match... Last edited by Sinister; 11-06-2009 at 09:43 AM. |
11-06-2009, 12:54 PM | #5 | |
Spanked once
Like this.. http://67-72chevytrucks.com/vboard/s...37&postcount=1
11-06-2009, 07:48 PM | #6 | |
Future TOTM Winner
