Old 11-06-2009, 03:11 AM   #1
WinDancer
The Original HotRod KnifeMaker
WinDancer's Avatar
t400 tranny sticking between gears @ low rpm?
I have a 396 in my truck. Under feathered throttle conditions my tranny reaches a point where it constantly [like 40-50 times per minute ] keeps changing from 1st to 2nd and then back again, over and over and over.
With moderate throttle it works perfectly.
Had a new B&M adjustable modulator put in with no change- the mechanic says the 400 has no carb-to-tranny cable to adjust it correctly like the t350's do.
Has anyone actually had this problem? Were you able to get it corrected? What did you do?
Thanks,
Dave
Dave
69 GMC SWB 2WD 454 Turbo 400
WinDancer is offline   Reply With Quote
Old 11-06-2009, 12:58 PM   #2
mtdave2
newly minted old timer
mtdave2's Avatar
Re: t400 tranny sticking between gears @ low rpm?
still sounds like a modulator to me.. id crank the sensitivity down a bunch and see if it stops. What tells the trany to shift is the modulator.
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 11-06-2009, 01:18 PM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
The TH400 does have a vacuum line that hooks to the modulator. Make sure there is not a leak in that line.
I am assuming you don't have some wild cam installed in the 396 that is lowering the vacuum signal too low. You should be seeing 14"+ at idle.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
