Jonny
C2500 upper ball joint into a C20 UCA?
I was wondering if anyone knows if a upper ball joint from a 88-98 C2500HD or C3500 will bolt into the upper control on my 83 C20. I am exploring ways to lift my truck and would like to put lift spindles on it. I know I could use a C2500 light duty spindle, but then I would be swapping to 6 lug and I don't want to loose my 14 bolt ff rear as I don't think a 12 bolt will stand up to the power of the cummins that's in the truck. I've already grenaded 2 14 bolt semi floating axles in this truck and I would think they were stronger than the 12 bolt, but correct me if I'm wrong.
Edit: I've already found out the lower ball joint will fit the lower control arm. I'm also wondering if the 8 lug rotor might fit on the 6 lug spindle?
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR Last edited by sailed2japan; 11-06-2009 at 06:58 AM. Reason: More info |
Jonny
Re: C2500 upper ball joint into a C20 UCA?
Well from looking at the auto zone web site it seems the 6 and 8 lug rotors are the same diameter and thickness, but use different wheelbearings and different calipers. Now I am wondering if the inner diameter of the wheel bearings is the same and if the 8 lug caliper will bolt to the 6 lug spindle.
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
Dually Pride
upper balljoint on 73-87 has 4 factory rivits that you gring out and replace with 4 bolts, not sure about 87+ trucks
If I have to explain, you wouldn't understand. '74 Chevy C-30 350/4 speed/dually ![]() '94 Ford Ranger |
Still plays with trucks
Sounds like it is time to go play around at the pull-it-yourself junk yard and see what works.
Happy to be here
![]() Join Date: Mar 2000
Moved to Suspension to see if you get better results.
Jonny
Can this go back to the 73-87 forum?
Happy to be here
Done...
Glad to see you are still planning this. Take pics and notes when you get around to doing this.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
See if your local auto parts store has both ball joints and match up the grease boot metal trim flanges to see how the bolt placement compares.
I have done this in the past with car ball joints to facilitate spindle swaps so why not on a truck. If NAPA doesn't have them they will ship them from their local warehouse to the satellite branch free of charge usually the same day if you don't live near a store that has them both. All it will cost you is a little time.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
Jonny
That's what i thought about doing I jst hate to hassle them with my mock up bs when I know they have plenty to do as it is.
#11 | |
Don't forget to give them account number 1200 for the preferred customer discount at NAPA if you don't all ready have an account you can use to get the better pricing.
Jonny
Napa is one of the companies I love because not only do they have great quality parts and staf, but they also give a military discount, same as preffered, to all active and reserve customers. I always support the companies who support us troops.
#13 |
Have you thought about the the 8 lug spindles...fabtech part number FTS2588-7
for the 1992 - 1999 chevy c2500/c3500.. I've been wondering if these will match up to our A arms...
www.cardomain.com/id/pooz911 |
#14 |
Jonny
Tat's what I am looking into right now. I've been on a break from this fora few days as I just found out that my frame is bent. I still plan on looking into it in the near future. I did get a chance to compare the C2500 upper ball joint to the C20's. It doesn't look like the C20 ball joint will fit the C2500 spindle, but it does look like the two outer holes will line up and you could then drill a new pair of inner holes. I haven't taken one on my control arms in, yet that's the next step for me. I'll let you know how it goes.
#15 | |
#16 |
Jonny
I checked the stud diameters and the 2500 definately has thicker studs. I checked the taper angles with my clibrated eyes and they seem the same. I'm thinking that the way to go is going to be to mod the c20 arm to accept the 2500 ball joint.
Edit: The 2500 lower will press into the C20 lower.
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR Last edited by sailed2japan; 11-18-2009 at 11:33 PM. |
#17 |
Where is your frame bent?
#18 | |
Sounds like it is time to buy a 2500 upper ball joint and fit it to the C20 upper a-arm to see if the relocated bolt holes cause an issue. I would shy away from the stud sleeve route if modifying the C-20 a-arm is at all possible. I think getting the larger stud size of the 2500 ball joint is preferable in a truck.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars Last edited by 68 TT; 01-11-2010 at 01:17 PM. |
#19 |
any updates????
