Old 11-06-2009, 09:44 AM   #1
my69camaro1
Young One
Question 2 1/2ton Rockwell install info/pics needed.
I have a set of military rockwells still under a M35 6x6 that I'm looking to install under a 80's Suburban or 80"s pickup... Just for a mud/trail truck...
If anyone has done the swap on here can I get some detailed pics of the steering and suspension setup?
Also how much lift is needed to clear ~48's...
I have the axles, one locker, a 1990 12v cummins motor, and a couple th400/np208 setups laying around... I have a few mil blazers but I want to build a longer wheelbase rig...
69 R/S Camaro
79 K5
86 M1008
11 P71 Vic
12 Ram 3500
18 Ram 2500
my69camaro1 is offline   Reply With Quote
Old 11-06-2009, 09:53 AM   #2
my69camaro1
Young One
Re: 2 1/2ton Rockwell install info/pics needed.
Oh, I used the wrong search the first time... Found several threads on here...
69 R/S Camaro
79 K5
86 M1008
11 P71 Vic
12 Ram 3500
18 Ram 2500
Old 11-06-2009, 10:36 AM   #3
csa daddy
csa daddy's Avatar
ok first ya need to debrake the axles cut all the brake parts away from axle housing . then get a set of pinnion brakes from diy4x4 measure for the spring perch width an put them under the truck . you can either run hydro assit steering or full hydro .my suggestion full hydro .you need to get a load sensitive orbital valve an one that you can still turn even if motor is not running . you will probly need atleast 20 inches of lift in order not to cut the fenders. you can build a set of drop hangers an use some big lift springs .with or without bod lift completely up to you .you can put big blocks an springs in the rear just ave to have some traction bars comeing off the bottom of the axle .here is a couple of pics of mine under my 97 chevy by the way the hogs head will be pointed at the chevy side i think it is to start
csa daddy is offline   Reply With Quote
Old 11-06-2009, 07:31 PM   #4
onlyifihadachevy
Are you going to do a build thread here?
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 11-07-2009, 12:48 AM   #5
csa daddy
csa daddy's Avatar
who
Old 11-07-2009, 01:27 AM   #6
onlyifihadachevy
My69, Youu too if you have one,but i thought you had one.
My 72 thread
Old 11-07-2009, 01:49 AM   #7
csa daddy
csa daddy's Avatar
na i dont think so
Old 11-10-2009, 07:17 PM   #8
my69camaro1
Young One
My brother just bought a 69 GMC 4x4 1/2ton that we might end up doing the build on... If so we'll do a build thread..
69 R/S Camaro
79 K5
86 M1008
11 P71 Vic
12 Ram 3500
18 Ram 2500
Old 11-12-2009, 11:10 PM   #9
Chevrolet4x4s
Chevrolet4x4s's Avatar
Good lookin truck
Shane
1993 K1500 350 5 speed
1985 K10 Silverado Vortec 406 5 speed (in body shop)
"I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been
No, I ain't broke I'm just broken in"
1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle )
Member#20327
Chevrolet4x4s is offline   Reply With Quote
Old 11-13-2009, 12:03 AM   #10
csa daddy
csa daddy's Avatar
i got a 68 chevy longbed 50 anniv truck that is going to be setting on rockwells an 52 or 48 inch tractor tires not sure yet got a set of 52 now but realy want 48x31x20 tractor tires
