troubleshooting help, pressurized fuel tank
Hey All,
OK, so fairly recently I have encountered thsi problem with the '85 pickup. If I tighten the gas cap fully after re-fueling, and drive the truck, I often get pressure building up in the gas tank. Sometimes to the point that it pushes fuel out the top of the tank somewhere, and it drips on the ground. Sometimes it doesn't get to the point of leaking, but when opening the gas tank cap, there is a 'wooosh' of pressure being released. I can't recall exactly when this started in relation to the tank replacement, to think if the 2 may be related in any way. My 'solution' has been to leave the gas cap loose maybe a quarter-turn. Stock engine/fuelpump. Seems to start and run fine, although I think it may be running kind of rich from the smell of the exhaust. Any thoughts on where I can look for the cause of this. Hate to waste precious fuel, seeing it puddle on the ground under my truck. ![]()
TomS. '98 S-10 Blazer 4dr 4wd - 4.3, AT, stock & '85 K-10 w/ 305, 700r4, np208, and RUST! SOLD Dec 2014 |
No No
Re: troubleshooting help, pressurized fuel tank
Well its normal to have a small amount of pressure built up in the tank. This large amount of pressure would lead me to beleive maybe someone disconected and plugged the charcole canister under the hood or debree had pluged the line. Now my memory is going these days all down hill since the big 30 lol. IIRC you should have a vented gas cap on that setup. Its also possible the vent on that is trashed and you can solve the issue by getting a new vented gas cap.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
