Old 11-06-2009, 11:03 AM   #1
Chevys4ME
67 donor?
First off i am new to the site and i have been looking around at some of the threads last couple of days and i sure wish i would have found this site years ago.
I have a 67 swb and i was wondering what you guys would suggest for a donor vehicle to help with the parts i need. I want to put tilt steering in it, power brakes,power steering, change from 6 to 5 lug.
I was wondering if i could swap the whole front sub fame or if i have to change just the spindles?
Chevys4ME is offline   Reply With Quote
Old 11-06-2009, 03:17 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: 67 donor?
71-72 1/2 ton chevy
front end stuff, swap rearend use power booster stuff and tilit, well maybe find used or buy new..
John
1999 Toyota Tacoma 4x4
Old 11-06-2009, 09:58 PM   #3
Re: 67 donor?
The tilt column restricts you to 71/72 to get it all from one vehicle.Van columns work up until column ignitions came along awhile later and are cheaper than 69-72 truck columns.If you want a vehicle for all that except the column you can go right up through the 88-98s.I`m not sure if you can just swap the knuckles with tie-rod ends on the 88-98s,but the 73-87s you can.
