1970 Daily Driver
Clutch Slave Setup
I have a clutch slave set up on my fire wall for my NV3500. Because of where I ran it the reservoir interfered with the power brake booster. To solve this I had to notch the plastic clip that attaches the reservoir to the slave cylinder and rotate it causing it to be cockeyed. I have seen some slave cylinders that have a small vertical cup style reservoir. Would it be possible to change out the reservoir to that style? I will post pictures of my setup and one simmilar to the one I would like to install. The set up I have on now came off of a 1992 1500 Chevy truck.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
The Few, The Proud
![]() Join Date: Jun 2007
Re: Clutch Slave Setup
It's very possible that you could change out the reservoir cup, but I'm not sure if they sell them individually or not. I'm installing a hydraulic clutch in my '69 and I bought a Wilwood master cylinder kit from Jeg's that came with different shaped reservoirs for different mounting applications. It even came with a hose so you could mount the reservoir elsewhere all together.
![]() Here's a link for the kit I bought for my '69. http://www.jegs.com/i/Wilwood/950/260-3374/10002/-1
Shannon |
I put a hyd clutch in my `70 C-20. I put a `90 5 spd in it and it required a hyd clutch. I had to make an 1 1/4" offset for my pedal arm and drill the firewall. It works great and after 2800 miles no problems.
1970 Daily Driver
Beuford, do you have a picture of the otherside of your fire wall, showing the clutch master cylinder setup?
motor exploder
i had a '92 Chevy C1500 with a NV3500 and it had the black clutch m/c with the little 'cup' reservoir on it kinda like the small unit (the L shaped one) in the second pic. You may be able to get one from O'Reilly's or something or maybe a junk yard if you want to go that route. I have a Wilwood unit (like what sdailey shows) on my '69 right now that works my McLeod hydraulic t/o bearing and it works great.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 11-09-2009 at 11:58 AM. |
