c20 to c10 conversion?
I am looking to change my c20 over to a c10 and was wondering if i have to change the whole front suspension over. I would think that the upper and lower control arms are the same, so i figure maybe i could just change out the drums and whatever else right there and that should be good right?
65 ![]() 00 Mustang GT 07 Honda CBR600RR |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: c20 to c10 conversion?
Are you converting to disc brakes at the same time?
C20 lower control arms are different than C10 lowers. The balljoint hole in the C20 lower control arm is larger. (Upper and lower balljoints are also different)
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 11-07-2009 at 12:51 PM. |
The outer tie rods are also different sized
67GMC Slammed
I did this to my 67,,, bought a 87 suburban for $500.. swapped out everything. complete front crossmember with all suspension.. and axle,, instant 5 lug and dics brakes....
Naw, i was gonna stay with drums for now. I ended up getting a full suspension with the c20 from a 63 c10 when i bought it.
Is it safe to say that i probally should change out everything when i convert over to 1/2 ton?
67GMC Slammed
hey I got the stock sindle from that 87 suburban with brakes on it, I was going to use it but I ended up buying a drop spindle kit with all new disc brakes from CPP at the last pomona swap meet.. you can have it.. not sure how far you are from me,,,
yes.
Five lug or 6?
Happy to be here
![]() Join Date: Mar 2000
#11 | |
The 5-lug 'burb suspension will require you to change to disc brakes. (Master cylinder and porportioning valve also)
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 11-08-2009 at 11:42 PM. |
67GMC Slammed
its a 5 lug set up, got the matching master cyclinder with booster too..
#13 |
![]() Join Date: Apr 2008
Early Classics has a lower control arm ball joint that fits the C20 arm and the C10 spindle. I believe they have the tie rod end conversion as well.
I am doing the same conversion and am using all the C20 equipment but converting to lowered C10 5 lug spindles and disc brakes.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
#14 |
Resurrecting...( a really old thread)
![]() Since my '68 is a C20 what are my options (staying 8 lug) to get disc brakes up front? ...and a drop? Ideally I would like to drop the truck some and also get disc brakes. I believe staying 8 lug (since I am finding some 8 lug wheels I like) might be the easier route to go since I could just stick with the rear axle I have now. Also, ...a major kudos to LoLife99 (Kieth) for putting this together: Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 A huge help indeed. Thanks! Last edited by KevinK7; 03-08-2018 at 11:40 PM. |
#15 |
www.performanceonline.com sells 8-Lug drop spindle kits.
That’s the best option for disc brakes and a correct method to drop your truck.
#16 | |
