Old 11-07-2009, 05:28 PM   #1
50Bow-tied GMC
What is the ideal weight in the back of an AD?
I am doing a bit of research as to what is the ideal weight in the rear of an AD. I am trying to figure out what is the best weight to traction ratio. The biggest thing that I am afraid of is breaking the tires loose every time I go to take off from a dead start. I wouldnt mind being able to do it from time to time but would like to keep more than 6 months between new tires in the rear. Also, if anyone has added weight to the rear how did you do it. I thought about filling the back half of the frame with lead after boxing it in, welding steel plates in the frame, or building a box full of something to put in the bed. Any ideas?
50Bow-tied GMC is offline   Reply With Quote
Old 11-07-2009, 08:06 PM   #2
OrrieG
OrrieG's Avatar
Re: What is the ideal weight in the back of an AD?
In my world the ideal weight is probably beer, expensive import or micro brews. A bunch of aluminum BBC would do nicely too.
OrrieG is offline   Reply With Quote
Old 11-07-2009, 08:12 PM   #3
sgtusmc
sgtusmc's Avatar
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 11-14-2009, 06:32 PM   #4
Atomsplitter
Atomsplitter's Avatar
I've never heard of someone adding weight to a daily driver for traction (winter?) unless your talking about racing?
If your talking about a daily driver try not to push your foot down so hard unless your trying to light um'up, works for me and it's better on the wallet (i.e. fuel and tires).
If i'm off base here just shoot me.....I'm old and tired anyway!
Atomsplitter is offline   Reply With Quote
Old 11-14-2009, 07:02 PM   #5
solidaxel
solidaxel's Avatar
Just how big is your power plant!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 11-15-2009, 01:40 AM   #6
OrrieG
OrrieG's Avatar
I think it is more a factory of throttle control than weighting up the rear. If you have an auto trans, get a little higher stall converter so it does not lock up as quick. Set up the throttle linkage so you need more movement on the foot side to open the throttle. Increase throttle return spring tension. I know guys around here running 700+ hp motors on the street with no problems. Putting the gas tank in the rear will help with weight distribution.
Is the back going to be a narrowed 4 link so you can run larger tires and work with the chassis set up to get the rear to hook up rather than spin? It's not a factor of weight or light weight drag cars and trucks would not work. Running the gear ratio higher will decrease wheel spin too.
Lots of things can affect the ability to decrease wheel spin, most important is how hard you mash the throttle.
Old 11-15-2009, 11:28 AM   #7
mr48chev
mr48chev's Avatar
Sooo, You don't have the truck running yet and are worried about the rear tires breaking loose when you leave stop lights?
That is better controlled with the proper use of the right foot than trying to scab weight onto the frame.
Old 11-15-2009, 12:20 PM   #8
PDW HOTRODS
PDW HOTRODS's Avatar
Install a new gas tank under the back of the bed. Its not adding weight, just moving it. Most people dont like the gas tank in the cab anyway.
PDW HOTRODS is offline   Reply With Quote
Old 11-15-2009, 10:36 PM   #9
50Bow-tied GMC
Thanks for the input guys. I wondered if I was out in left field for being worried about it when it comes right down to an issue of controlling the right foot.
Old 11-17-2009, 03:40 PM   #10
Atomsplitter
If you're really worried about this issue, use a wider rear tire for more traction and it will tend to grip better than a skinny tires. I use 245/70r15's on the rear. With 300hp and 330ft/lbs I can still drive normally when I want without spinning the tires but I still have trouble keeping it under the speed limit (it only weighs 3200lbs).
Old 11-17-2009, 11:34 PM   #11
cobinder
Everything is work in progress
cobinder's Avatar
Move your fuel tank and your battery to the rear. Adjust your ride height. Thats the easy/ cheapest way to move weight to the rear and gain traction.
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
Old 11-18-2009, 02:23 PM   #12
mylow53
mylow53's Avatar
pretty hard to brake my tires loose with 340 hp (posi rear) and 10" wheels. i've done it but the go peddle was on the floor. are you going big block?
GT
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 11-18-2009, 11:54 PM   #13
50Bow-tied GMC
Atom: Thanks for your input. I didnt really think about the wider tire making it harder to breakem loose.
Co: I am planning on moving the fuel tank back to the back, but hadnt thought of the battery too. How do you access it?
Mylow: Probably will go with a small block.
