Old 01-20-2003, 09:06 AM   #1
zlivewire
drilled holes in 203 for more oil
put in shaft kit workes great only problem smells like gear oil was in it i top off with 10w40 only drove couple miles home should i drain and put all 10w40 or should i use synt 75w90 i drilled 2 quarter inch holes in lip in t/case to get more oil in tail any input would be great
zlivewire is offline   Reply With Quote
Old 01-20-2003, 11:29 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Welcome to the board. I'm now 4X4 guru but what is the correct oil for the case?
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 01-21-2003, 04:31 PM   #3
zlivewire
it calls for 10w40 what about the holes should i open it up and plug them
Old 01-21-2003, 04:38 PM   #4
arveetek
Ultimate Diesel Dude
arveetek's Avatar
Go to www.coloradok5.com and ask the 4x4 gurus over there. That's the best place I've found for 4x4 information.
Project truck: '81 C/20 converted to 6.2L TURBO DIESEL bored .040", gear drive, 6.5L injectors/pump, custom pistons, custom 4" exhaust, 700R4, 4.10's
Daily Driver: '95 K1500 Tahoe, 6.5L TURBO DIESEL, NP241, 4L80E, 3.42's
arveetek is offline   Reply With Quote
