Old 11-07-2009, 06:15 PM   #1
ScottH
ScottH's Avatar
Will a ps box from an 83 bolt in a 68?
I have a 68 with stock power steering however the box is leaking pretty bad.
I can get another box from a 83 but need to know if it will bolt in and use the same hoses that I have on now.
If anyone could shed some light on this change I would really appreciate any insight.
Scott
1963 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 11-07-2009, 07:26 PM   #2
boogie67
boogie67's Avatar
Re: Will a ps box from an 83 bolt in a 68?
It will bolt in but you have to change your hoses or use the pump off the 83.I did it on my 67.
77 swb starting all over again.
boogie67 is offline   Reply With Quote
Old 11-08-2009, 10:08 AM   #3
grayw0lf
What all years will bolt in place?
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 11-08-2009, 12:36 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You don't have to change to the later model pump just because the hose ends are different. You just unscrew the 1 inch hex fitting out of a late model pump and screw it into your old pump. They interchange and this gives you the proper fitting you need for the late model hose.
Old 11-09-2009, 11:43 PM   #5
70C10Toejam
Hellasick
70C10Toejam's Avatar
the big problem I had with using an '85 ps box on mine was not finding any metric-o-ring lines that would fit the truck. Just convert the '83 to a flair line box.
http://67-72chevytrucks.com/vboard/s...d.php?t=242458
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 11-10-2009, 04:40 PM   #6
ScottH
ScottH's Avatar
Great info guys, thanks!
