11-07-2009, 07:22 PM | #1 |
Backspace for 15" wheel?
Will 15x8 6x5.5 4.25 Backspace work on a 66? Want to order my smoothies next week.
11-07-2009, 09:50 PM | #2 |
Resistance is Futile
Re: Backspace for 15" wheel?
I believe so...depends on how big a tire and how low the truck sits. I think the truck Rallys have 4.25'' BS also......I'm running a 295/50/15 on the rear of my burb on Rally rims.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device Last edited by protrash64; 11-07-2009 at 09:51 PM. |
11-08-2009, 08:02 AM | #3 |
How big of a tire are you going to use?
Fleetside or stepside? |
11-09-2009, 02:18 AM | #4 |
I agree with protrash64 ...depends on how big a tire and how low the truck sits. I also believe the truck Rallys have 4.25'' BS .....I'm running a 305/50/15 on the rear of my 62 with on Rally rims.
11-09-2009, 03:28 AM | #5 |
I measured my 6 lug rally spare the other day. I thought I came up with 3.75" backspacing. I'll have to double check tomorrow.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
11-09-2009, 04:04 AM | #6 |
I'll do the same and measure mine also ...
11-09-2009, 11:00 AM | #7 |
I have a 5 - 7 drop and was planning on trying to run something like a 235/70/15 or so.
Guy in Classic Truck mag has the same setup and ran Coker Classic bias-ply WW, 7.60-15 which is what I am trying to translate too. |
11-09-2009, 11:22 AM | #8 | |
C10slim, I ran stock truck rallies (3-5/8" b.s.) and P235/75R15 on the front, 31x10.5x15 on the rear, with no clearance issues. Don't know if the 4-1/4" b.s. will give you any issues on the front or not. They won't be a problem on the rear. Hope this helps. Last edited by lakeroadster; 11-09-2009 at 11:24 AM. |
11-10-2009, 10:46 PM | #9 |
Hey Slim,
I am running 6 lug 15X8 with a 4" backspace on my 65. I have to run 1/4" wafer spacers to clear the late model brake calipers, so that makes the real backspace 3-3/4". If you are running drums that shouldn't be a problem. I am running P235/75R15 tires, plenty of clearance for them. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
11-10-2009, 11:28 PM | #10 |
I measured again today. That's what I come up with, 3.75".
11-11-2009, 04:06 PM | #11 |
Awesome guys exactly what I needed!!
TR65 - I have converted to disc also. You got the look I am after except I am going to run white walls. |
11-11-2009, 10:10 PM | #12 |
The difference in backspace must be between 6-lug and 5-lug. My Rallys are 5 lug....4.25'' bs.
I also have no clearance issues with disc brakes, dropped spindles, and bags.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
11-11-2009, 10:59 PM | #13 |
Hey Slim,
I really like the smoothy look as well. Hey Pro, It may be the position of the drop well that causes the interference so it probably depends on the particular wheel design. TR
11-11-2009, 11:15 PM | #14 |
This is the look I am going for although the new cragar wheel with a chrome spider cap is starting to grow on me also.
