Old 11-07-2009, 11:07 PM   #1
harshard
Question Cross member question
I recently picked up a short frame rolling chassis and noticed that the cross member where the trans. support bolts is a lot less heavy duty than the one on a long bed. Is this standard for a short frame? Can it be changed to the heavier one? Why are there two types? Thanks, Shawn
harshard is offline   Reply With Quote
Old 11-07-2009, 11:10 PM   #2
powell72
powell72's Avatar
Re: Cross member question
It looks like someone cut the brackets off that go to the top of the frame to make it easier to remove. Auto trans crossmembers are the same regardless of wheelbase. I'd swap yours in.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 11-08-2009, 08:01 AM   #3
Jim_PA
Camaros, and probably other cars had ones similar to that.
I've often thought about putting something a little easier to remove in there.
Jim_PA is offline   Reply With Quote
Old 11-08-2009, 08:33 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
someone removed the upper legs off the crossmember.
I would swap them out and install the good one. This piece does help stiffin things up a tad bit, even though it is a PITA to remove.
