Old 11-08-2009, 12:44 AM   #1
Puropedo
Anyone running 315/35/20's on the rear?
Im concidering going this wide for the rear of my project, did some research and came up with 28".5 overall tire diameter, not bad, plus the width of the tire makes it look sick. Anyone running them out there? Maybe a pic? Thanks.
Puropedo is offline   Reply With Quote
Old 11-09-2009, 02:49 AM   #2
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Re: Anyone running 315/35/20's on the rear?
I'm wondering if you're not going to have to tub out your bed to make those tires work. 315's are pretty wide.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 11-09-2009, 04:31 AM   #3
Puropedo
I have an eye on a set of those, and yes they seem pretty wide (that's the reason why I like them) I might have to tub my bed like you said. If I get them, I will install them on my 20x10 Coys, so once installed they will narrow just a bit, here's a pic of them...
Old 11-09-2009, 07:03 AM   #4
big_al_71
big_al_71's Avatar
I am not sure if this truck has the exact size but I think it is though.....this is a truck that belongs to a friend of a friend of mine..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 11-09-2009, 02:40 PM   #5
SCOTI
SCOTI's Avatar
Those look like Mickey T Radials which would be slightly wider than the 315mm is.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-10-2009, 12:02 AM   #6
Puropedo
Thanks for the pics Big Al 71, those M/T sure look killer, Scoti is right, they seem a little wider than the 315's
Old 11-10-2009, 01:17 AM   #7
big_al_71
big_al_71's Avatar
No problem just trying to help....
Old 11-10-2009, 02:10 AM   #8
Hart_Rod
Hart_Rod's Avatar
If your friend's friend decides to get rid of those, I'll take them off his hands.....
I think ERIK D's truck has 315's on the rear...
Hart_Rod is offline   Reply With Quote
Old 11-10-2009, 08:40 AM   #9
big_al_71
big_al_71's Avatar
Rob, if he decides to sell the truck that biatch will be in my garage
Old 11-10-2009, 12:21 PM   #10
Ackattack
Ackattack's Avatar
I have 315/35/20s on Project Bruiser. They are on 20x10" wheels with 5.75" BS, which puts the tires within about 1/16" from the outer wheel well when fully dumped
I did tub the rear wheel wells. If you look at my build thread, I have a picture of one of the tires mounted up with no wheel well, so you can see how close the tire would be to the stock wheel well.
Overall, I really kinda kick myself for not narrowing a 9" to run less back spacing. I'd probably have close to the same as what I do in my 12 bolt. Oh well....to late now.
Ackattack is offline   Reply With Quote
