11-08-2009, 01:10 PM | #1 |
metal wire loom
Who sells a good metal wire loom?I need it for a few wires around the areas that could rub or be too warm with out unprotected it.
11-08-2009, 01:23 PM | #2 |
What?
Re: metal wire loom
I doubt anyone makes anything like that, at least I have never seen one.
It sounds like something that would have to be fabbed up.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
11-08-2009, 03:04 PM | #3 |
Re: metal wire loom
i've used the woven mesh aluminum looking heat shield type of tube stuff with good results i got it from both summit and speedway motors// something made out of metal asorb and trap heat i'd think
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 11-08-2009 at 03:06 PM. |
11-08-2009, 03:17 PM | #4 |
chevy truck fan
Re: metal wire loom
what about using tubing?? it would be some work, but it would be protected & would look pretty good....??
11-08-2009, 04:11 PM | #5 |
Re: metal wire loom
Metal tubing is the cool way to go, even GM used it for awhile on the wires near the starter.
You could also use the asphalt wire covering, a little harder to find in large sizes. I have used and still use the small size for one or two wire applications, works great. Mick |
