Clutch pedal trouble
My clutch pedal will not return the last 1 1/2 inches to the full release position and the truck won't move w/o me lifting it with my foot. I have ordered new bolt, spring and bushings from LMC. Will this replacement of "worn" parts solve the problem?
Re: Clutch pedal trouble
Did I miss data on your truck....i. e. year, engine, transmission?
Ooops!! 1983 GMC Dump Truck dually. Crate 350 with a three speed manual and an additional low gear for pulling.
![]() Join Date: Feb 2009
Is your clutch pedal parallel to the brake or is it shifted left at the bottom?
I've found that well used clutch pedals fatigue with time and start to bend to the left and eventually hit part of the steering column/pedal core support under the dash preventing the pedal from being able to return fully. A new bushing will help too, but may not be the ultimate solution.
-Don- '66 ![]() '77 ![]() '80 ![]() '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf ![]() Last edited by Oilbrnr; 11-09-2009 at 04:45 PM. |
Oil: clutch pedal is parallel to the brake pedal. Yup, it is also rubbing a little on the bracket. I figured that the bushing would help align the pedal.
#6 | |
![]() I can't remember, but isn't the '83 a hydro clutch?
-Don- '66 ![]() '77 ![]() '80 ![]() '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf ![]() |
Moderator
![]() Join Date: Oct 2008
I can't remember, but isn't the '83 a hydro clutch?[/QUOTE]
No... `85 is when they started. Kinda scarce too. |
