Still plays with trucks
Any tricks to remove spray paint markings?
Are there any tricks to removing spray paint markings (like from a junk yard) on a body panel without damaging the original paint underneath?
My 78 K20 came with a pair of straight front fenders that are even the same color as my truck but the vehicle was at the end of a row and had spray painted markings on them. While we are at it are there any tricks to removing the grease pencil markings they put on everything?
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
3/4 Ton Rodder
Re: Any tricks to remove spray paint markings?
I think gas removes the grease pencil markings.
1981 Chevy Scottsdale C20 "Orange Crush": SOLD 1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy. |
spray paint comes off a ton easier than the stock paint. you can probably use acetone or brake clean without hurting the factory paint. a good polish might even take the spray paint off.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
Happy to be here
![]() Join Date: Mar 2000
brake fluid, acetone? Come on guys, he is trying to save the paint.
I would hit it with a clay bar and see what happens. For any tough spots, trying working it with mineral spirits.
Redefining LowBudget
STOP STOP STOP
easy off oven cleaner ( YELLOW CAN ONLY) and a soft paint brush...... spray the spay paint let it sit for a couple min the gently brush away the spray paint..... Wash the truck clean then IF NEEDED lightly buff by hand then a good coat of wax this is the quikest easiest way to remove vandle marks or even door lettering and it safe for the OEM paint as long as you dont let it sit there for a loooong time what it does is work from the edges in you'll see it
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
Badass
oh didnt know u wanted to save the paint
dont use my ideas
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90
Wow! Vandal Mark Remover. It is made to remove spray paint.
http://www.randmh.com/vandal-mark-re...ning-products/ There are a lot of companies that make this stuff. You could ask at your local hardware or parts/Auto bay supply store. Or you can google it.
I can still count my vehicles on two... wait three hands. |
Slots go on anything!
Lacquer thinner will work too. Just wax it afterwards.
claying the panel should work if the paint is in good shape
Good ole WD - 40 might be good on the grease pencil (?) 3M makes an "Adhesive Cleaner" that I use at work for cleaning and degreasing electrical enclosures before I scuff and paint them. That might be good also. Also - buffing compound ?
Thanks for the suggestions. I will try mineral spirits first then lacquer thinner since I have them on hand then go to the store for some yellow can easy off if needed.
I will document the process to see what works and what doesn't.
#13 |
I do have some of the 3M adhesive remover so I will give that a try too.
#14 |
78 Big10 454
![]() Join Date: Jul 2008
My work vehicle got "tagged" and rubbing compound removed the spray paint without any damage.
#15 |
That is good to know. I will give it a try if the other things I have on hand don't work.
#16 |
#17 | |
I was assigned the horrible task of having to test fire a batch of 400 M-16's that we just finished converting from full auto to 3-round burst ![]() We were shooting them though a concrete culvert pipe on the M-60 machine gun range in case one went out of control. One of the SP's watching went and got a Kevlar helmet and set it on the culvert pipe. He pulled out his 9mm side arm and took a shot at it. All it did was chip the surface of the Kevlar. He turned it around and took a shot at it with his personal 45 ACP. It went flying and ended up with a huge dent in the inch thick Kevlar that almost made it all the way through. It for sure would have broken your neck if it hit you. He then had me take a shot at the helmet with the M-16 with standard NATO green tip rounds, nothing special. The .223 went clean through both sides of the helmet without even knocking it off the culvert pipe. Dead meat.
#18 |
78 Big10 454
That's why I always enjoyed carrying a 1911 Colt on my hip when I was in the Army.
"Nobody lies to a .45" |
| Bookmarks |
