Old 11-09-2009, 03:33 PM   #1
62 Bowtie
62 Bowtie's Avatar
sprung a leak
popped the hood last night and noticed the paint was peeling off the inner fender which prompted me to check the master cyl that was ok then this combination valve and sure enough it's leaking its comming from the center fitting the one with a bleeder pin. I noticed some of you guys dont have this prop/combo valve,can i just remove it and bolt directly to the mc or should I just by a new prop/combo block
62 Bowtie is offline   Reply With Quote
Old 11-09-2009, 05:20 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: sprung a leak
The combo valve is essential to balancing the pressure between the front and rear brakes. Some that don't appear to run the valve have mounted it somewhere else. Mine is on the front crossmember below the motor perch on the drivers side. It makes changing spark plugs much easier and looks cleaner. I also lost my share of paint before getting everything buttoned up.
Old 11-09-2009, 06:58 PM   #3
64Magoo
Re: sprung a leak
Trucks trashed. Time to give me the truck and just get a new one, it's the only option
64Magoo is offline   Reply With Quote
Old 11-09-2009, 09:09 PM   #4
Rich 5150 69
Rich 5150 69's Avatar
Re: sprung a leak
Bowtie try moving the pin in/out several times to see if it quits leaking, other wise replace, by the way we`re neighbors.....
Rich 5150 69 is offline   Reply With Quote
