Old 11-09-2009, 04:52 PM   #1
Sinister
Between Trucks...
Sinister's Avatar
Today's Project
Threw my power steering belt on the freeway doing 70 mph. Fun.
Went to put a new belt on and discovered the bracket was broken and one of the bolts was broken off in the engine block. Welded a nut to the broken bolt, welded the bracket back together. (Luckily broken piece was held on by a nut on the pump. ) Waiting for the girlfriend to get back so I can go to the hardware store and finish up. Does the bracket look right? I had closed up the piece I welded with some new metal, but I cut it back out because it didn't look like the pump would go into the bracket closed up. Also anybody know what size the little bolt is that goes in the front of the bracket and pump? Bolt would go in the hole on the bottom right, front of pump. 350 SBC.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 11-09-2009, 07:56 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Today's Project
cant answer your ? but good luck getting it fixed , how long did it take you to realize you didnt have power steering on the freeway lol good thing your still here
John
1999 Toyota Tacoma 4x4
Old 11-09-2009, 08:49 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
Re: Today's Project
Fixed mostly. Still trying to figure out the bolt that goes in the front. Tried a 3/8" course, gonna try the next size down. Felt the belt go as soon as it went. Could still steer though, so just drove it home.
Beat it to fit,
Old 11-09-2009, 09:51 PM   #4
badassciviv
badassciviv's Avatar
Re: Today's Project
i believe that bolt will be a 5/16 fine thread if it is going into the block
[B][/B]
James
68 GMC SHORT FLEET 4x4
83 Dodge short fleet 2x4
2000 Civic SI
badassciviv is offline   Reply With Quote
Old 11-09-2009, 10:02 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
Re: Today's Project
Thanks for the reply. The bolts going into the block are O.K. They're 3/8" course thread. There's a bolt that goes into the front of the bracket into the pump I'm trying to figure out. 3/8" course was too big. Gonna try 5/16" next.
Beat it to fit,
Old 11-09-2009, 10:47 PM   #6
AustinScott
AustinScott's Avatar
Re: Today's Project
My stock power steering bracket had the same cut out for the rear bolt. I also thought it was hacked up.
Check out the bottom of this thread to see what I mean.
http://67-72chevytrucks.com/vboard/s...d.php?t=365766
AustinScott is offline   Reply With Quote
Old 11-09-2009, 11:23 PM   #7
Sinister
Between Trucks...
Sinister's Avatar
Re: Today's Project
Cool thanks. Now if I can just figure out that bolt, I'll be good.
Beat it to fit,
