Old 11-09-2009, 05:03 PM   #1
steve53
steve53's Avatar
clutch question
Hey guys,
Got a question for some of you that may have run into this. I am putting a '65 250 straight six in my '53. I have the correct bell housing and the only thing left is to wonder what size clutch will fit on my original three speed. I have the clutch for the 250 but I have no idea what size clutch is on the 216 currently in my truck. I believe it is a 9" but im not sure. Will a clutch disk from the 250 fit on my three speed is the question?
53 Chevy 3100 1/2 ton
1st Armored Division, OIF Veteran
steve53 is offline   Reply With Quote
Old 11-09-2009, 05:41 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: clutch question
It may. slide the disc on the input shaft and see. If its ok use all the 250 stuff. I would be more concerned with the trans fitting the bell.
dwcsr is offline   Reply With Quote
Old 11-09-2009, 06:14 PM   #3
steve53
steve53's Avatar
Re: clutch question
i found the bellhousing i am using from this article over on the stovebolt
http://www.stovebolt.com/techtips/en...lhousings.html
Old 11-09-2009, 06:14 PM   #4
steve53
steve53's Avatar
Re: clutch question
problem is, i want to have all my ducks in a row when i do the swap because this truck is my daily driver and i want to have as little down-time as possible.
Old 11-10-2009, 12:07 PM   #5
Bigblue29
Thanks 'til you're better paid
Bigblue29's Avatar
Re: clutch question
I am going through this now with my 235 striaght 6 swap back into my 50 3100. When I bought it, it had a worn out 60's 235. I found a good running '61 235 to put back into it. The clutch I pulled out was 9 1/8" so thats what I am putting back into it. I have a 4speed on the floor and am keeping my floor stomp starter, and reusing my old bell housing.
I would be willing to take pics of anything for you if you want. I have most of it sitting in my garage waiting for me to install the clutch which should be delivered today.
-Luke
1950 Chevy AD 3100 pickup
2000 GMC Sierra
1970 Jeepster Commando
Bigblue29 is offline   Reply With Quote
Old 11-10-2009, 03:37 PM   #6
steve53
steve53's Avatar
Re: clutch question
please take as many pics as you can! i will probably be going through this in a couple weeks. i would appreciate it!
Old 11-10-2009, 04:53 PM   #7
Bigblue29
Bigblue29's Avatar
Re: clutch question
I think things will be a little different for your swap since you are using a later model 230-250 block. If you were going to swap a 261 or a 235 the blocks are similar and my pics maybe a little more helpful. But I will take them, as I was going to post it anyways!
-Luke
2000 GMC Sierra
