Old 11-09-2009, 05:46 PM   #1
68gmsee
Active Member
68gmsee's Avatar
Anyone know of a non smelly chemical dip.
I took apart a quadrajet and need to soak it. Does anyone know of a non smelly chem dip for carburetors that works.
I drove around town today to all the local auto parts to see if I could find a chemical solution other than Berryman Chem-Dip. I bought some a few years ago and my wife had me remove it from the premises cause it stunk up the garage- and the neighborhood.
I actually spilled some on the ground and even after burning some wood trimmings on top, I could still smell that stuff.
68gmsee is offline   Reply With Quote
Old 11-09-2009, 06:08 PM   #2
UltraBlue71
UltraBlue71's Avatar
Re: Anyone know of a non smelly chemical dip.
But it sure does work good!
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG...
71 LWB
UltraBlue71 is offline   Reply With Quote
Old 11-09-2009, 06:19 PM   #3
mbgmike
Haha That stuff do stink. Yah it do. Varsal works but it stinks. Most all do but you should vent any parts cleaners outside. We sell Wurth products and offer some brake cleaner products that are enviro friendly." Sharp Shooter" brand. They are Brake cleaners but work on carbs. Their are many brands. SafetyKlean makes some also. They don't have a bad odor.
Check online for some more. Brake cleaners that are chem based don't smell as bad for a long time but will take off most finishes on carbs. If you soak them long enough that purple cleaner that most stores have will remove carbon and does a decent job. We use it to clean intakes.
mbgmike is offline   Reply With Quote
Old 11-09-2009, 06:56 PM   #4
Jayss109
Active Member
Jayss109's Avatar
Believe it or not, but use some Simple Green. Not quite as effective as the nasty stuff, but you wont kill your braincells either! Little more time with a bristle brush, and its safe to use on practically anything. Will make the garage smell nice!
J
Cadillac Powered
Jayss109 is offline   Reply With Quote
Old 11-09-2009, 07:31 PM   #5
68gmsee
Active Member
68gmsee's Avatar
The carb is not that dirty on the outside. I wanted to remove scale and deposits left when the carb set for a couple of years. I guess I could get some small wire brushes and use elbow grease, but I want to make sure I clean all the small internal holes.
While doing an internet search, I read of someone recommending Gunk chem dip carb cleaner but I can't locate any around here. Maybe someone here has used it and leave some input.
Old 11-09-2009, 07:51 PM   #6
mbgmike
J
Yeah the green and the purple are the same stuff
Old 11-09-2009, 08:15 PM   #7
diggertodd
diggertodd
diggertodd's Avatar
I hang on the garagejournal website too, there was a great thread there by those who swear by submersing carbs in green antifreeze, 48 hours = absolutely clean.
- Todd Silvey
diggertodd is offline   Reply With Quote
Old 11-09-2009, 08:24 PM   #8
68gmsee
Active Member
68gmsee's Avatar
Green antifreeze??? Like the stuff you use in the radiator?
