Old 11-09-2009, 09:24 PM   #1
KrazyKevin
What have I gotten into
KrazyKevin's Avatar
Where to find U-bolts for rear axles?
Whats the best place to buy the two big u-bolts that holds the rear end to the trailing arms? Is there a place on the net that has a good rep, or is it better to go through GM? For that matter, how bout for other bolts? Tractor Supply? Lowes? HomeDepot? Or online?
Thanks for any input.
Kevin
1972 Chevy SWB Fleetside
Project BumbleBee
KrazyKevin is offline   Reply With Quote
Old 11-09-2009, 09:28 PM   #2
white 67
Re: Where to find U-bolts for rear axles?
i got new ones with my lowering blocks from cpp. Im not sure if they sell just the bolts.
white 67 is offline   Reply With Quote
Old 11-09-2009, 09:52 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Call:
City Spring & Brake Service
798 College St
Beaumont, TX 77701
(409) 833-5695
and tell them what you are looking for. If they don't have them they can either make them or order them for you. A set should be about 30 bucks.
LockDoc
Leon
Old 11-09-2009, 09:56 PM   #4
KrazyKevin
KrazyKevin's Avatar
Thanks very much. Will do first thing tomorrow. If ya don't mind me asking, how did u locate these guys?
Thanks again
Kevin
Project BumbleBee
Old 11-09-2009, 10:02 PM   #5
LockDoc
LockDoc's Avatar
Thanks again
Kevin
No problem Kevin.
After looking up Liberty, TX in Google Maps to see what it was close to I typed "automotive springs beaumont, tx" into Google. (without the quotes)..
Google is your friend.
LockDoc
Leon
Old 11-10-2009, 12:22 AM   #6
cdowns
cdowns's Avatar
local autopartss store,spring shops too
Old 11-10-2009, 12:23 AM   #7
ERASER5
ERASER5's Avatar
Auto Zone has them all day long for less than $20.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 11-10-2009, 01:16 AM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I went to a local spring shop, bade them while I waited, and they were considerably better than the ones I got from LMC 5 years ago or so.
Old 11-10-2009, 02:07 AM   #9
Hart_Rod
Hart_Rod's Avatar
Do you need a standard length set? If so, I've got a new set, cover shipping and they're yours.
Hart_Rod is offline   Reply With Quote
Old 11-10-2009, 07:41 AM   #10
KrazyKevin
KrazyKevin's Avatar
I'm gonna check my O'Rielys and Autozone on my way home today. If they don't have em, I might give you a yell Hart_Rod. Very nice of you to offer. I wonder what the shipping is from FL to TX? Think its gonna be around 5lbs?
THanks a million guys.
Project BumbleBee
Old 11-10-2009, 01:04 PM   #11
Hart_Rod
Hart_Rod's Avatar
I can throw them in a fla rate box for around $10.
Old 11-10-2009, 01:38 PM   #12
tim21391
tim21391's Avatar
i went to local spring and axle shop and they made me new ones for like 20 bucks
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 11-10-2009, 04:27 PM   #13
leddzepp
Moderator
leddzepp's Avatar
Yup...
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 11-10-2009, 10:31 PM   #14
eric67m
eric67m's Avatar
Schucks has them for 10.99 for one u bolt. $44 an axle. These were the larger 3 3/8 ones. I year ago a spring shop charged me around $50 for an axles worth. Now I need them for a different axle swap. Might just go the pull a part route.
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
