Old 11-09-2009, 11:11 PM   #1
bigdon-70blazer
1970 Blazer rear carpet hold down strip
This is out of mine, completely stock and factory. It is not like all I have seen but I have come to expect this in these earlier runs of the Blazer. I am trying to replace this rubber weatherstrip the is glued to this metal strip. I have included the pics. I just need a flat piece of weatherstrip rubber that is 2 inches or so wide that I can glue down as you see it. Any of you have a source for weatherstrip sort of close to this that you have used in similar or different applications? It would be great if I could find this exact part but since I have only seen this one, chances are slim...
bigdon-70blazer is offline   Reply With Quote
Old 11-09-2009, 11:14 PM   #2
bigdon-70blazer
Re: 1970 Blazer rear carpet hold down strip
2 more...
Old 11-10-2009, 08:28 AM   #3
vtblazer
vtblazer's Avatar
I have one that looks exactly like that, rubber in the same condition as well.
No idea for a replacement source right off but maybe wondering around one of those huge hardware stores could produce something close, at least close enough so that it could be cut down and used.
vtblazer is offline   Reply With Quote
Old 11-10-2009, 08:42 AM   #4
pound41
garage door rubber will give you a flat piece with a bend that might work
pound41 is offline   Reply With Quote
Old 11-10-2009, 09:37 AM   #5
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
You can go to a place that sells truck caps they will have alot of different width but it sticks on one side and I dont think it is rubber.
1972 GMC Jimmy 1/2 4X4 4wheel camper
1970 GMC Jimmy 1/2 4X4 350
1969 Chevy Blazer 1/2 4X4 307
1967 chevy LWB 3/4 396
Gary 70 Jimmy is offline   Reply With Quote
Old 11-28-2009, 09:57 PM   #6
bigdon-70blazer
Pound41 is a genious! I went and found some of this stuff from a hardware store in town and found a garage door seal that is nailed to the bottom of the door. It looked to be a perfect shape for the application we need. So I brought it home and the strip worked better than I imagined. I have included pics of the installed part, bag it came in then you will see pics of the bed after fatmat installation. It worked great!
Old 11-28-2009, 10:03 PM   #7
bigdon-70blazer
More
Old 11-28-2009, 10:07 PM   #8
bigdon-70blazer
Pictures a little out of sequence but you get the idea...we all like pics. Here are some more...
Old 11-29-2009, 10:01 AM   #9
bigdon-70blazer
Important detail pic!
Old 11-29-2009, 10:30 AM   #10
Bentblazer
Bentblazer's Avatar
Just looked at mine yesterday and will have to do the same; yours is looking good!
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
1930 Chevy two door rat
Bentblazer is offline   Reply With Quote
Old 11-29-2009, 10:59 AM   #11
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
tHATS A SLICK IDEA ON THE BOTTOM SEAL AS THE REPLACEMENTS SUCK..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-30-2009, 10:11 AM   #12
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Great Pics! Cool idea. My Jimmy is a 72 with Cheyane package... I dont recall Any seal on the bottom of the tailgate... the strip was there though... yep, it was a different strip than yours.
Tom Vogel is offline   Reply With Quote
Old 01-03-2010, 03:53 PM   #13
joemacho
joemacho's Avatar
thats sweet man
joemacho is offline   Reply With Quote
Old 01-03-2010, 08:18 PM   #14
Firebirdjones
That looks much more effective than the factory rubber strip on our 72 blazer. Ours is one piece that also runs along the side rails on both sides. Ours actually fits into a slot that is made into the stainless trim,,,not glued in like yours.
Problem is though, ours only sticks out about 1/4 inch at the most and really doesn't crush that well against the tailgate when it's closed. I've always said that section of weatherstrip needs to be thicker for a better seal.
And yours looks to be doing that. Great info.
Firebirdjones is offline   Reply With Quote
