Old 11-10-2009, 01:11 AM   #1
50adrod
50adrod's Avatar
S10 driveshaft question
what hve you done for a driveshaft on your s10 swap? I have an extended cab short box so I will need to shorten the frame already and then move the 4.3 V6 back 6 inches also. did you just cut your factory shaft that much?
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 11-10-2009, 03:10 AM   #2
Thadious
Re: S10 driveshaft question
That's pretty much what I did... machined out the end, cut it off for what I needed, rewelded it back together, machined the weld and then took it in for balancing and repainted it.... done.
Mine's the 2 pc shaft w/ 3 Ujoints as well... just for the record.... I cut the short shaft.
Cheers,
Ted.
'51 Chevy Build - In the design stages
Aut viam inveniam aut faciam - I will either find a way or make one.
If you don't have time to do it right the first time, when will you...
My new build - https://67-72chevytrucks.com/vboard/...70#post8958970
Thadious is offline   Reply With Quote
Old 11-10-2009, 11:02 AM   #3
BlueJeep
BlueJeep's Avatar
I haven't done mine yet, but I'm either going to modify the 2 piece shaft or switch to a 1 piece shaft. I've found that 4wd and 2wd shafts are different lengths (obviously, because of transfer case) and I think I can mix and match parts and get pretty close to what I need.
FYI, I'm using an extended cab s10 frame and then I cut 2.375" from the front of a long box and running boards and it's going to work pretty slick.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
