Resident Curmudgeon
![]() Join Date: Dec 1999
OE Dash Wiring Harnesses for sale
$30 each plus shipping
Both are for 3 speed manual with guages, can be used with automatics if you don't mind not having a neutral safety switch. Harness 1 - Has backup light connector cut off, a replacement is included.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Resident Curmudgeon
Re: OE Dash Wiring Harnesses for sale
Harness #2 - No wires cut, but ignition switch connector is broken. A replacement is included with tis too
Resident Curmudgeon
ttt
Resident Curmudgeon
ttt
intrested in harness 1 is the fuse box corroded and how much to ship to pa 17756 thanks mike
67 short bed stepside tach tilt buddy buckets bagged sittin on 20s and 4w disc brakes (not quite finnished) ![]() |
Resident Curmudgeon
I'll take a closer look for you. Shipping in flat rate USMail priority box for $11
Intrested in #2 shipping to 90706
Resident Curmudgeon
i will take harness 1 pm me your info thanks mike
Resident Curmudgeon
CPNE put me in line shipping to 23462. A home address.
Kerry
1969 Chevelle 1990 IROC Z Convertible 2002 Silverado LT |
Do these harnesses include the under hood, and the wires to the tail lights?
#13 |
Resident Curmudgeon
No, just the fuse box and all wiring for cluster and switches under dash.
#14 |
Ready, Set, Off-Road!
![]() Join Date: Nov 2009
Hello is harness 1 available?
#15 |
Resident Curmudgeon
