11-10-2009, 10:27 AM | #1 |
whats the trick?
i am needing to replace my front windshield on a 1980 chev. i have tried to pull 2 out of salvage busted them both- i was using very little force- got the nylon glass spoon lots of wd-40 and took my time- even cut most of the old seal out-please help i am running out of donor pickups-
11-10-2009, 11:30 AM | #2 |
Robert Olson Transport
Re: whats the trick?
I always cut the heck outta the old gasket after removing the center strip . I wind up if its stuck to the gasket using piano wire to cut the windshield away from the rubber
they also sell a tool for this but it isnt cost effective if you only do this once in a while
11-10-2009, 11:39 AM | #3 |
yea if i remeber correctly we even used old guitar strings to cut the windsheild out of my camaro.
11-10-2009, 11:42 AM | #4 |
Run a screw driver around the weather stripping on the outside to loosen it up and spray the wd40 under the seal. The gently push on the top of the windshield. work your way back and forth and take your time.
I bought a new windshield about 5 years ago for about $75. Shaded with the antenna. A used one was $50 if they pulled it. Maybe the price has gone up, but for the price I'd rather have a new one.
I can still count my vehicles on two... wait three hands. |
11-10-2009, 11:48 AM | #5 |
Trucks do not use a sealant. Camaro is different. It uses the ribon seal.
11-10-2009, 02:52 PM | #6 |
yeah new ones are too cheep to be trying to use old ones. I got one installed last year for under $100.
11-10-2009, 07:05 PM | #7 |
I think mine was about 150.00. New gasket and locking strip, and they came to the house. After pulling out the old one and discovering rust holes, I wasn't going to deal with the installation.
I cut the snot out of the old gasket, a couple of putty knives and silicone spray. I wasn't trying to save the old one, it just came out that way.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. Last edited by donut; 11-10-2009 at 07:10 PM. |
11-10-2009, 10:37 PM | #8 |
11-10-2009, 11:52 PM | #9 |
No worries.......
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end" |
11-11-2009, 12:56 AM | #10 |
use a utility knife with a brand new blade, go on the inside of the truck, and cut between the pinch weld and the outer piece of the gasket. Its about 3/8-1/2 wide if i remember rite. once that is completely cut off (mostly the sides and top) you can push the upper corners with the palm of your hands and it will slowly start to unstick, depends if anyone has used sealant or not. I usually have someone on the outside ready to catch it. Me and dad take em out in about 5-10 min tops. Hope this helps.
77 chevy k10 Bonanza-Restored when i was 17 76 chevy c10 short box-scrapped 81 chevy c10 silverado short box-project 64 impala 2 dr hard top-project waiting to get started |
11-11-2009, 01:02 AM | #11 |
i have always cut the gasket if you wan the glass, and break the glass if you want the gasket.
i run a razor tracing the glass 100% the way around. have always come right out. |
11-11-2009, 09:53 AM | #12 |
I always cut the gasket on both sides with a utility knife then gently tap the glass to break it loose. I have one in my garage that I'm not going to use. Too bad you aren't closer. I'd sell it to you cheap to get it out of my way so that I don't accidentally break it. ...Joe
I'm not speedin'! I'm qualifyin'! |
11-13-2009, 06:33 PM | #13 |
a big thanks to those who gave me advice- i finally got me a windshield out without breaking it(3rd times the charm) now if i can just get it put in!
